is there a list of o-ring part numbers (by location) or a kit that i can buy?
I'm replacing all of the major components except for the compressor itself?
volvopartswebstore has a microfiche, but it looks very cluttered and hard to read. fcp no longer sells an o-ring kit for the car.
I need o-rings for.....
Evaporator
-pipe closest to pass side fender: QTY:
-pipe closest to driver side fender: QTY:
orifice
-rear: QTY:
-front: QTY:
Junction on pass. side frame rail: QTY:
Condenser
-Inlet(driver): QTY:
-outlet(pass.): QTY:
Drier
-Inlet: QTY:
-outlet: QTY:
i'll update this as i find the correct part numbers...not sure if this will be useful to others
98 s70 t5 a/c o-rings
cjbmustang
Good parts diagram for the ac system is here:
http://www.eeuroparts.com/Cars/Volvo/17 ... C-Heating/
Click on "Open Diagram".
The eeuro diagram is the one I used, it is great!
Replace every Oring you see - they cost about a buck, and each leak you don't fix costs you 20 USD minimum in R134A charge.
cjbmustang
wow, that is a better diagram. the other one looks like an eye-spy picture...
thanks a lot for the link
- 1005 Views
Last post by JRev
- 1173 Views
Last post by theWIFES_S70
- 1203 Views
Last post by SleeStak69
- 4399 Views
Last post by 93Regina
- 1030 Views
Last post by northernlights
