98 s70 t5 A/C problem
I have a 98 s70 with an a/c problem. the recirc light and ac off light flash for 20 seconds when I start up. every function on the ecc work except for ac it doesn't kick the compressor on but the compressor works when I took off the relay cover and manually supplied power that way. Anyone have any ideas or wiring diagrams for the ac unit because I really don't want to take it to the dealer
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 20 times
Is the air cold when you jump it? Is there refrigerant in the system?
IF there's refrigerant in the system, a pressure switch may be bad.
'98 S70 T5
2016 Chevy Cruze Premier
jblackburn
Jump the low pressure switch with a paper clip and add freon to it. Do not let it pull it below 15 psi. It is on the line at the top right of the engine compartment.
Reconnect the switch when it is holding steady and make sure the compressor will stay running.
'98 S70 T5
ok, so now everything seems good with the ecc, no lights are flashing. I jumped the low pressure switch and made sure I had enough Freon in it and we are good but the compressor and fan don't kick on and when I jump the relay only the compressor kicks on. Where else should I look to next??
- Has thanked: 1613 times
- Been thanked: 4077 times
You can't do too much more diagnosing without manifold hoses. You could try a used/new low pressure switch. The have a valve under them so you won't lose the refrigerant charge on removal
JimBee
- Has thanked: 33 times
- Been thanked: 43 times
Tracing upstream from the low pressure switch: The system works when you jump the low pressure switch.
The low pressure switch works when you trigger the relay.
But the relay isn't triggering on demand (as set by the ECC dash control). I would grab my multi-meter and determine if I'm getting signal input to the relay (you're getting voltage, b/c it's powering the rest of the system when you manually close it, right?
If you're getting an input signal to the relay, then the relay is strongly suspect. If no signal into relay, then what's next upstream from there?
jblackburn
What do you mean it doesn't work? The compressor turned on, didn't it?johnmc70 wrote:no the system doesn't work when I jump the low pressure switch and I check the relay and 13v are coming out of 1,2, and 3. Does this sound like a bad relay?
The fan kicks on when the high pressure side reaches a certain PSI
'98 S70 T5
- 1596 Views
- 12 Replies
- 3430 Views
Last post by Jaguar xjs
- 19 Replies
- 7471 Views
- 15 Replies
- 7860 Views
Last post by tango_1000
- 2590 Views
