1999 v70xc as tow vehicle?
v70xclace
Year and Model: v70xc, 1999
Post by v70xclace »
We are preparing to transport a small kayak trailer from Chicago to Missouri and we were hoping to use the V70 to tow it. I've been looking around and it seems that there is only one style of hitch (a class II) that is for this car however, we were hoping to install a class III hitch on it (this one: http://www.diggerslist.com/sale/heavy-e ... III/93819/) is this possible?
any recommendations, suggestions, tips, tricks, etc are welcome :)
Thanks!!!
Has thanked: 1614 times
Been thanked: 4078 times
A Class III hitch is rated at >5000 lbs towing capacity which exceeds that of your V70. A typical small kayak trailer only weighs 200-300 lbs so a class I would be fine.
I tow small trailers, boats, and even a large boat with my V70 often.
If you want the 2 inch receiver capacity you can get that in a Class II.
I dont think you will find anyone who will install a hitch rated more than the car, for obvious liability reasons.
BEJinFbk
Year and Model: '98 V70 R
Has thanked: 94 times
Been thanked: 146 times
Post by BEJinFbk »
There's no class III hitch because the car
isn't designed to haul that large a load.
JRL
Year and Model: Several
Been thanked: 16 times
Post by JRL »
Make sure you put new transmission fluid in BEFORE you do this
jpr0204
Year and Model: 12' XC70 Prem. Plus
Post by jpr0204 »
+1 to what JRL said...
Also I would like to add to his post...
If you plan on traveling with this load behind you for quite awhile until you reach your destination, the addition of a small auxillary transmission cooler (that can be had for about $30-$40) which splices into your exsisting tranny cooler lines will do wonders for getting rid of the heat from the transmission while towing which will extend the life of your transmission tremendously since heat is the number one killer of transmissions.
- Joe
Current Vehicles:
20' Kia Sorento (Lease) (Fiancé's car) Currently at 19,500 miles
12' Volvo XC70 Premier Plus AWD Currently at 95K miles
12' Yamaha V-Star 950 EFI Tourer (My daily summer crusier) Currently at 5K miles
04' Yamaha V-Star 650 Classic (Fiancé's daily summer cruiser) Currently at 16K miles.
precopster
Year and Model: Lots
Been thanked: 128 times
Post by precopster »
If it's high speed travelling and very little steep mountainous climbing you can omit the cooler. Transmission damage is done in stop/start conditions and hard acceleration at low speeds.
I would definiteley replace fluid.
I'd be more worried about choosing the right person to install the wiring as the '99s V70s were the first year with CANBUS.
v70xclace
Post by v70xclace »
Thank you all for your help!
Illinois to MO is pretty flat. A small kayak trailer is about the same load as three meat-eating adults.
For a one time longer flatlands trip, I would skip the cooler. If you were trailering your boat to Pikes Peak every weekend, I would get the cooler.
Some where I have the instructions for wiring my OEM Volvo hitch on my 1999 V70 - Ill see if that adds value and upload it
v70xclace
Post by v70xclace »
Thanks abscate! that would be helpful. the wiring part does make me nervous and my "guy" might not be able to fit us in :-/ I've done a little bit of wiring work before; it may be something I could handle (maybe not). I'm still not sure if we'll even go this route and not use a rental or something. But, so long as the car can handle it ( I THINK it can), it would be handy to have it outfitted with a hitch.
