I have lights out in three of my radio duttons and the sun roof button. Can anyone tell me how to replace the light bulbs in these?
My car is a 1999 V70 XC
thanks
How do I replace lights in radio buttons, & sun roof but
Guest
you can easily replace the light in the sunroof switch you can get the light from the dealer and pull the switch out the light goes rt. in. the radio on the other hand is a different story i dont think you can replace the lights i only have three working the only fix is a new radio they dont sell replacement lights.
White850Turbo
- Year and Model:
I have heard of people replacing the bulbs in the radio, but I'm told that it requires somewhat complex disassembly of the unit.
-Sean
1998 S70 T5 (Almost Stock)
I replaced the lights in my radio. I have the sc810 in a 93 850. I removed the radio (after making sure I had the code), removed the front face plate and the circuit board in behind. The lights on mine were soldered to this curcuit board. I un-soldered the existing lights and re-soldered new ones purchased at Radio Shack/The Source. Although the new lights are dimmer than the old ones, at least they work. If you're not good with the solder, take the board and new lights to any electronics repair shop and they should be able to do it for you. There is a link on the Volvospeed site that gets you part way through this procedure. The lights on that example were the push and turn style, not the soldered style. Otherwise, the radios are a dime-a-dozen on eBay. Maybe buy a new one..... Hope this helps.
93 850 GLT
Canada
Canada
- 847 Views
Last post by ovlov058R
- 1213 Views
Last post by packetfire
- 16 Replies
- 2402 Views
Last post by vtl
- 632 Views
Last post by phils94850
- 538 Views
Last post by rspi
