Stupid question - how do I know if I have 4 or 5 spd auto?
Enid Puceflange
Year and Model: XC70, 2000
Post by Enid Puceflange »
OK, I *know* this sounds very stupid, but I have a 2000 XC70, and I'm about to replace the front driveshafts and I need to know. If it has a four speed auto, the transmission selector in the car offers 3,2 and 1 as options, right? And if it were to be a 5 speed it would offer 4,3,2,1 yes?
I tried to use the Wiki VIN decoder to no avail, as the trans comes out as manual, which I *know* isn't right :)
Needless to say I'm at work, its at home and I need to order the parts quickly in order to get them here in time...
Thanks in advance...
Has thanked: 1611 times
Been thanked: 4072 times
Well thats not a stupid question when the VIN decoder has led you astray! I think if you can drive it I would take it up to highway speed and count shifts.
A lot of cars dont offer all gears selectable in an AT, so I dont think I would use the shift selector as definitive.
In a rush - order both and return the other...??
jpr0204
Year and Model: 12' XC70 Prem. Plus
Post by jpr0204 »
Hi,
In short the answer is:
All 2000 V70 X/C's came with the AW 50-42LE 4-Speed Automatic.
Hope this helps... :)
- Joe
Current Vehicles:
20' Kia Sorento (Lease) (Fiancé's car) Currently at 19,500 miles
12' Volvo XC70 Premier Plus AWD Currently at 95K miles
12' Yamaha V-Star 950 EFI Tourer (My daily summer crusier) Currently at 5K miles
04' Yamaha V-Star 650 Classic (Fiancé's daily summer cruiser) Currently at 16K miles.
Enid Puceflange
I love you guys - thank you!
jpr0204
Post by jpr0204 »
The AW 50-42LE 4-Speed Automatic will have the P, R, N, D, 3, 2, and 1 while the AW 50-55N 5-Speed Automatic will have the P, R, N, D, 4, 3, and L.
In 00' all AWD and Turbo models used the AW 50-42LE 4-Speed Auto Trans, while Non-Turbos used the AW-50-55N 5-Speed Auto Trans.
The 4-Speed Auto in my opinion is MUCH better the 5-Speed Auto.
The 4-Speed Auto uses good old regular DexronIII/Mercon fluid and is pretty much a solid unit and can go many miles on just "dain N' fills" and a couple shift solenoids when the mileage gets up there around 200K + while the 5-Speed Auto requires the use of expensive JWS-3309 spec fluid which is a bit pricey and has numerous problems.
- Joe
Current Vehicles:
jblackburn
Year and Model: 1998 S70 T5
Has thanked: 9 times
Been thanked: 20 times
Post by jblackburn »
jpr0204 wrote:The AW 50-42LE 4-Speed Automatic will have the P, R, N, D, 3, 2, and 1 while the AW 50-55N 5-Speed Automatic will have the P, R, N, D, 4, 3, and L.
- Joe
What he said. You can tell by the shifter gate pattern.
I wish the 5-speeds were as reliable; they really are set up better for acceleration across the speed range. The 4-speeds are pretty much bulletproof as long as you change the fluid in them.
Some 00 non-turbos also had a 5-speed, and 2000 V70R's used this transmission as well.
'98 S70 T5
2016 Chevy Cruze Premier
JRL
Year and Model: Several
Been thanked: 16 times
Post by JRL »
NO 1999s came with a 5 speed and yes the 2000 V70R also uses it
alanjackson
Year and Model: V70 2006 D5
Has thanked: 2 times
Post by alanjackson »
Hello all, I have the same question for the same reason - I need a l/h drive shaft for my petrol 2001 V70 2.4T aoutomatic and have no idea if it is 4 or 5 speed. Any suggestions anyone? Many thanks
Year and Model: Many Volvos
Been thanked: 76 times
Post by Ozark Lee »
My understanding is that all of the '01s had the 5 speed but you should post this question in the P2 forum for confirmation. If the number on the shifter below drive is a 4 then it is for sure a 5 speed. This forum cuts off at 2000 except for the C70 and many of us struggle answering C70 questions.
tryingbe
Year and Model: None
Has thanked: 1 time
Been thanked: 26 times
Post by tryingbe »
alanjackson wrote:Hello all, I have the same question for the same reason - I need a l/h drive shaft for my petrol 2001 V70 2.4T aoutomatic and have no idea if it is 4 or 5 speed. Any suggestions anyone? Many thanks
Owner's manual says 5 spd.
http://volvo.custhelp.com/app/manuals/O ... /om_id/767
85 GLH, 367 whp
00 Insight, 72 mpg
