Did you know? 🤔
1999 V70 T5 5 speed Nautic Blue
Keep track of your Volvo's maintenance here. Keep track of what you did, when, and how much it cost.
Forum rules
Has thanked: 192 times
Been thanked: 618 times
Trinidad & Tobago
Post by abscate » Mon Jul 15, 2013 11:13 am
Repair log in service as family car
Roughly 15000 miles per year
Purchased 2000
Reset service light procedure
On the 1999
Ignition off.
Press in trip odometer reset button.
Switch on ignition.
Continue pressing in the reset button for 10 seconds. (Sing one third of the "Final Jeopardy" theme
Release reset button within 4 seconds.
Cut a piece of black electrical tape about 3/4" by 3/4" and place it over the light
Horrible advice, Shirley....
It's 19mm x19mm, and the electrical tape colour must match the body exterior, of course.
ETB Code 10W481302 - Dec 2010 build/software date - Mike posted software after 2006 is current
Trinidad & Tobago
Re: 1999 V70 T5 High Pressure Turbo with 5 speed - asbcate C
Post by abscate » Mon Jul 15, 2013 11:14 am
CY 2009 Repairs and Records
Coil troubleshooting thread
http://www.matthewsvolvosite.com/forums ... il#p325109
Trinidad & Tobago
Post by abscate » Mon Jul 15, 2013 11:19 am
CY 2013 Repair Records
Jan 19 143100 miles
R/R Front rotors
R/R front pads
Front right caliper tight
1mm bleed screw, 10 mm on replacements
M6 rotor retain screw hand tight
8mm hex caliper retaining pin
15mm Caliper bracket bolt - blue Loctite
Replaced Radiator - seep on passenger side
New coolant
http://www.matthewsvolvosite.com/forums ... t5#p275430
Feb 2013
Poor running due to induction hose leak, poor installation
New spark plugs 143000
http://www.matthewsvolvosite.com/forums ... =1&t=54781
Change oil/filter/air filter/ cabin air filter
Replace evap core and AC hardware lines, accumulator, expansion valve
Shim AC compressor
http://www.matthewsvolvosite.com/forums ... t5&start=0
Replace front calipers - RHS freezing up
http://www.matthewsvolvosite.com/forums ... t5#p289371
Replaced ignition switch electrical
http://www.matthewsvolvosite.com/forums ... t5#p281691
Root failure analysis on ignition switch 9447804
viewtopic.php?f=1&t=80191
Replaced O2 sensors
http://www.matthewsvolvosite.com/forums ... t5#p284234
July 13 - replace coolant level sensor with new
http://www.matthewsvolvosite.com/forums ... el#p292579
p0327 and P0442 code, cleared, did not recur
Trinidad & Tobago
Oil use report
Post by abscate » Thu Aug 22, 2013 12:16 pm
High speed trip (ALB to Wall Street via EWR round trip)
400 miles at 75mph average
ambient road temp 90-95
Used approx one half hash tag mark on dip stick
Computer reported 25.1 mpg
Trinidad & Tobago
Re: 1999 V70 T5 High Pressure Turbo with 5 speed - abscate
Post by abscate » Wed Sep 11, 2013 11:45 am
CEL On, 149799 miles
P0442 Purge fault has been recurring
P0327 Knock sensor signal too low, shows up once in a while
Tested Purge Valve (later model) Resistance is 24.1 Ohms
Specification per AllData is Pulse ratio controlled valve. Resistance 29.7 ±1.4
Replaced Purge Valve, erased codes
Adjust parking brake
http://www.matthewsvolvosite.com/forums ... t5#p301094
Replaced MAP sensor on ETB
http://www.matthewsvolvosite.com/forums ... t5#p303447
Trinidad & Tobago
Post by abscate » Mon May 19, 2014 4:26 am
Trinidad & Tobago
Post by abscate » Thu Jun 05, 2014 11:40 pm
New wiper blades front
Passed NYS inspection with evap code not ready (600+ miles) per EPA regs
Trinidad & Tobago
Post by abscate » Sun Jun 29, 2014 6:16 pm
Repaired rear wiper, found broken wire in harness following left tailgate hinge, spliced with bullet connector. Followed good thread here
http://www.matthewsvolvosite.com/forums ... 3&start=14
Road trip. 70 mph ALB NYC reported 27 mpg.
More links on tailgate repairs
http://www.matthewsvolvosite.com/forums ... =9&t=47882
Trinidad & Tobago
Post by abscate » Mon Sep 22, 2014 12:41 pm
Replaced springs, shocks, delta links, trailing arm bushings rear.
IPD HD springs
Gained 1-2 inches rear ride height
Replaced springs, struts, all mounts, front
Replaced growler Front left wheel bearing with FAG
Installed IPD strut brace
Destroyed CV joint cage, inner doing job
Installed used left axle from Erie Volvo
http://www.matthewsvolvosite.com/forums ... t5#p340662
replaced Manual transmission oil with Valvoline Synthetic - no residue on magnetic plug
Oil filter change with Mobil 1 synthetic
http://www.matthewsvolvosite.com/forums ... t5#p342929
Repaired left rear ABS harness
http://www.matthewsvolvosite.com/forums ... t5#p352625
Miles 159XXX
Trinidad & Tobago
Re: 1999 V70 T5 5 speed Nautic Blue
Post by abscate » Mon Jun 29, 2015 6:16 am
Occasional P1332 CVVT solenoid code pops up, removed solenoid and cleaned in carb cleaner
Codes coming up less often, approximately 1500 mile intervals
Code does not pend.
