Did you know? 🤔
1999 V70 T5 M56 ELIZABETH Nautic Blue 417 Perfo 16 Wheels
Keep track of your Volvo's maintenance here. Keep track of what you did, when, and how much it cost.
Forum rules
Has thanked: 363 times
Been thanked: 1113 times
Trinidad & Tobago
Re: 1999 V70 T5 5 speed Nautic Blue
Post by abscate » Sat Jan 07, 2017 4:33 am
Engine coolant temperature sensor resistance chart for P80 and p2
Part 91866486 for P80
P80 1999 chart
P2 2005
Link To Volvo Glossary
Trinidad & Tobago
Post by abscate » Sun Jan 08, 2017 5:45 am
Can seal installation tool thread here
http://www.matthewsvolvosite.com/forums ... 1&start=20
Trinidad & Tobago
Post by abscate » Mon Jan 16, 2017 8:49 am
Visual Audible Tactile Hose Inspection here
viewtopic.php?f=1&t=79114&p=426011&hilit=vacuum#p426011
Trinidad & Tobago
Post by abscate » Sat Feb 04, 2017 4:43 am
Replaced radiator with Nissens jan 15, 185000 miles
ABS still faulting on right rear wheel - ordered new rear harness from FCP
Trinidad & Tobago
Post by abscate » Mon Mar 06, 2017 2:13 pm
March Volvo fest
Cleaned relay terminals. Nasty
viewtopic.php?f=1&t=80481&hilit=Albany&start=20#p434364
186500
NEW Bosch single electrode spark plugs. Old ones worn to between 035 and 040, whitish
Last serviced at 167000 miles:
Running NGK Cu plugs with 27000 miles on them. Car was running well, but gap had grown to over 0.040 inches. Spec in manual is 0.030 inches and many here recommend 0.028.
I regapped to a tight 0.030" fit.
Thinking back I'm not sure I checked gap on plugs out of box, but that was in a long since overwritten piece of RAM
Trinidad & Tobago
Post by abscate » Mon Apr 03, 2017 5:36 am
p80 bastard fuel pressure specs here
viewtopic.php?f=1&t=68182&p=362020&hili ... ed#p362020
Trinidad & Tobago
Post by abscate » Fri Apr 28, 2017 10:25 am
apr 28 190250 Oil change 10W-30, filter change.
Trinidad & Tobago
Post by abscate » Sun May 07, 2017 6:14 am
Great thread on AC performance by jimmy
viewtopic.php?f=1&t=50330
CVVT guts by jimmy
viewtopic.php?f=9&t=81207&p=439245#p439245
Trinidad & Tobago
Post by abscate » Tue Jul 18, 2017 11:31 am
Crank and immobiliser sequence documented here
viewtopic.php?f=1&t=81535&p=444597#p444597
Front ABS Sensor connections documented here
viewtopic.php?f=1&t=82046
Trinidad & Tobago
Post by abscate » Wed Sep 13, 2017 4:26 pm
Thread with specs on both interior and exterior climate system sensor specs..
viewtopic.php?f=1&t=82671&p=449722#p449722
