IPD sale Volvo Parts
Did you know? 🤔
1999 V70 T5 5 speed Nautic Blue
Keep track of your Volvo's maintenance here. Keep track of what you did, when, and how much it cost.
Forum rules
Has thanked: 189 times
Been thanked: 601 times
Trinidad & Tobago
Re: 1999 V70 T5 5 speed Nautic Blue
Post by abscate » Fri Jan 26, 2018 1:43 pm
abscate wrote:
Sat Feb 04, 2017 4:43 am
Replaced radiator with Nissens jan 15, 185000 miles
ABS still faulting on right rear wheel - ordered new rear harness from FCP
Finally got around to replacing rear ABS harness
Thread here
viewtopic.php?f=1&t=84246&p=461773#p461773
Mileage 199716
Trinidad & Tobago
Post by abscate » Sat Feb 17, 2018 9:49 am
Replaced front right ABS sensor. Sometime I had repaired this from a break between the straun relief
Used a Delphi from FCP, fit perfect
M6 to release sensor from hub
Two attaches and two clips to harness
Cleared P1550 and spurious P0137
ABS light cleared in self test
Mileage 200,937
Trinidad & Tobago
Post by abscate » Sun Feb 25, 2018 12:51 am
Detailed description of the P80 Evap sequence by user lexia
viewtopic.php?f=1&t=84507
Trinidad & Tobago
Post by abscate » Sun Mar 18, 2018 4:55 pm
Swapped in parts car driver seat skins for lower and upper seat part. Used nice skins from passenger seat of parts V70. Zip tied to stays. Applied leather conditioner. Also replaced seat bottom foam and heater
viewtopic.php?f=1&t=84734&p=466785#p466785
Trinidad & Tobago
Post by abscate » Thu Mar 29, 2018 8:52 am
Replaced Cabin air filter
R/R Evap vacuum system, found bad hose - root cause of occasional rough cold idle - thread here
viewtopic.php?f=1&t=84552
Added 1 liter oil, 2500 miles down a 203,000
Rerouted CBV pulloff vacuum hose.
Trinidad & Tobago
Post by abscate » Sun Apr 08, 2018 2:53 pm
Replaced last Purge valve hose from check valve to snorkel with 3/8 fuel hose - needed clamp on nipple.
Checked and adjusted turbo waste gate valve - one full turn CCW, out for 4.3psi at WGA
Mileage 204,000
Trinidad & Tobago
Post by abscate » Sat Apr 28, 2018 3:38 am
Oil and filter change at 206400
Replaced lower intercooler hose and clamps..tough job due to limited space
Replaced oil cooler seals
viewtopic.php?f=1&t=83718
Trinidad & Tobago
Post by abscate » Sun May 06, 2018 5:27 am
Replaced purge canister J hose and canister shutoff hose, tested canister shutoff valve
viewtopic.php?f=1&t=85260&p=471493#p471493
About one hour. Tight clearance for Oetiker clamp tool working under there
Silicon Spray sunroof guides
Tested AC on 90F day - awesome cold.
NYSI passed with no codes, all MON READY
Trinidad & Tobago
Post by abscate » Mon Jun 04, 2018 5:28 am
Added one liter oil at 207800
Replaced zip tie on passenger side radiator mount with throughbolt and nut
Fabricated lower mount washer with1 1/2 inch fender washer with edges bent up to clear approx 32 mm radiator flange. Held SS PHILLIPS in place with tape, hand started lock but ( hard clearance) , then vice gripped nut And tightened from below
Inserted top rad screws with SS Lowe’s hardware
Evaluated ball joint play, 90k miles? Approx 1mm radial...need replacing
Trinidad & Tobago
Post by abscate » Sat Jun 23, 2018 11:33 am
Replaced LCA with Lemforder, 2 hours 208911
viewtopic.php?f=1&t=85733&p=474970#p474970
