Did you know? 🤔
1999 V70 T5 M56 ELIZABETH Nautic Blue 417 Perfo 16 Wheels
Keep track of your Volvo's maintenance here. Keep track of what you did, when, and how much it cost.
Forum rules
Has thanked: 363 times
Been thanked: 1110 times
Trinidad & Tobago
Re: 1999 V70 T5 5 speed Nautic Blue
Post by abscate » Sat Dec 09, 2017 5:31 am
Replaced alternator and AC compressor to stop growl
Used Valeo AC 1999-2000 only. 3 hours labour
Right radiator mount hardware loose, zip tied and will repair
Replaced exhaust CVVT hub with used and retimed
viewtopic.php?f=1&t=83008&hilit=Cvvt+1999&start=10
197800
Link To Volvo Glossary
Trinidad & Tobago
Post by abscate » Wed Dec 13, 2017 3:06 pm
Oil change M1 10W-30 197800
Trinidad & Tobago
Post by abscate » Sat Jan 13, 2018 6:21 am
Recharged AC with 680g R134A at ambient of 60F
New pass wiper blade, retightened driver wiper arm
Tailgate latch replacement due to failed plastic internally
viewtopic.php?f=1&t=84018
Trinidad & Tobago
Post by abscate » Fri Jan 26, 2018 1:43 pm
abscate wrote:
Sat Feb 04, 2017 4:43 am
Replaced radiator with Nissens jan 15, 185000 miles
ABS still faulting on right rear wheel - ordered new rear harness from FCP
Finally got around to replacing rear ABS harness
Thread here
viewtopic.php?f=1&t=84246&p=461773#p461773
Mileage 199716
Also flushed PS and replaced with Pentosin
view-topic.php?f=1&t=78410&p=461886&hil ... in#p461886
Trinidad & Tobago
Post by abscate » Sat Feb 17, 2018 9:49 am
Replaced front right ABS sensor. Sometime I had repaired this from a break between the straun relief
Used a Delphi from FCP, fit perfect
M6 to release sensor from hub
Two attaches and two clips to harness
Cleared P1550 and spurious P0137
ABS light cleared in self test
Mileage 200,937
Trinidad & Tobago
Post by abscate » Sun Feb 25, 2018 12:51 am
Detailed description of the P80 Evap sequence by user lexia
viewtopic.php?f=1&t=84507
Trinidad & Tobago
Post by abscate » Sun Mar 18, 2018 4:55 pm
Swapped in parts car driver seat skins for lower and upper seat part. Used nice skins from passenger seat of parts V70. Zip tied to stays. Applied leather conditioner. Also replaced seat bottom foam and heater
viewtopic.php?f=1&t=84734&p=466785#p466785
Trinidad & Tobago
Post by abscate » Thu Mar 29, 2018 8:52 am
Replaced Cabin air filter
R/R Evap vacuum system, found bad hose - root cause of occasional rough cold idle - thread here
viewtopic.php?f=1&t=84552
Added 1 liter oil, 2500 miles down a 203,000
Rerouted CBV pulloff vacuum hose.
Trinidad & Tobago
Post by abscate » Sun Apr 08, 2018 2:53 pm
Replaced last Purge valve hose from check valve to snorkel with 3/8 fuel hose - needed clamp on nipple.
Checked and adjusted turbo waste gate valve - one full turn CCW, out for 4.3psi at WGA
Mileage 204,000
Trinidad & Tobago
Post by abscate » Sat Apr 28, 2018 3:38 am
Oil and filter change at 206400
Replaced lower intercooler hose and clamps..tough job due to limited space
Replaced oil cooler seals
viewtopic.php?f=1&t=83718
