Boost Gauge Not Working!!!
ManManOhMan
- Year and Model: 850 Turbo 1994
The boost gauge on my 1994 850 Turbo doesn't work (the gauge always stays in the middle no matter what). Can anyone give me any information on why it's not working and how to fix it? Thanks To All!
polskamafia mjl
- Has thanked: 19 times
- Been thanked: 21 times
ManManOhMan
I appreciate the link but this doesn't really give me too much clarity. Thank you for the response though!
polskamafia mjl
The link points out that the most likely failure is in the vacuum lines.
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
One link in that thread is another link to a thread that I made about the vacuum lines under the battery tray being worn through. You can also check the vacuum like behind the cluster, it may be loose.
wilson850r
- Year and Model: V70R 2005
- Been thanked: 2 times
+1 on the vacuum lines. My boost gauge did not work either on my 96 when I first bought it and even though car seemed to run fine, the turbo hoses needed replacement. After replacement the gauge started working again, but I also did replace a couple of the vacuum lines so can't be sure which had the most positive effect. I thrust the people who have replied to you in this thread because they sure have saved me a lot of time and money.
Rick
2005 V70R
1996 850R Sedan - Gone
1997 850R Wagon - Wrecked Sold
2006 Scion XB Special Release 4.0
2005 V70R
KnightAB
- Year and Model: 98 V70 XC 97 850 T5
Hi! I am dealing with the same issue on my 97 850. Can anyone link me to photos, or a diagram. of what hoses to look for that may need replacing? I am new to looking for turbo lines and I don't know what to look for. Thanks!
Jake Schmitt
- Year and Model: 1994 854 Turbo
The vacuum line for the boost guard is clipped onto the driver's side hood release cable near the battery and runs through a loom to connect at the throttle body.
