96 960 blown head gasket
cracked radiator at top hose connection lead to over heating. replaced radiator - unfortunately the head gasket went. white smoke pours out exhaust. has anyone ever tried myduraseal? I don't like using sealer but don't want to replace head gasket.. any thoughts? thank you...
jimmy57
- Has thanked: 5 times
- Been thanked: 322 times
No. Those products have some limited effectiveness on cast iron engines but open deck aluminum is low success rate. The dirty rotten secret of the magic elixir poured into radiators biz is the stopped up heater cores and stopped up oil coolers. In some cases plugged radiators. Your engine does have a coolant to oil oil cooler.
lindy8_man
- Year and Model: 1998 S90
"fun" project to change your gasket! Do that and check your compression and fluids. Hope and pray you did not warp your heads. I came close to your outcome myself in the middle of nowhere. Replace those radiators Ya'll! it's just a matter of time
Beer and DIY Volvo Repairs are proof that God loves us and wants us to be happy.
rgk
- Year and Model: Gray 88 245
- Has thanked: 1 time
grg probably did warp the heads. Even a slight warp will guarantee destruction of the new gasket. Do yourself a favor and take them to a machine shop where they will inspect the heads for free. Here in Carbondale resurfacing and cleaning costs $55. If there is a chance the heads are cracked, the shop can perform a pressure test, which with the resurfacing and cleaning costs $135.
rgk -- was dickdeadly
- 1347 Views
Last post by lummert
- 1966 Views
Last post by tryingbe
- 902 Views
Last post by Wvusaxplayer
- 14 Replies
- 3057 Views
Last post by jcdillin
- 2041 Views
Last post by crussell83
