Get on the VEXED mailing list
DonWillson
Year and Model: 2000 V70XC
Post by DonWillson »
The fight is not over. The extended warranty is a CARB (California Air Resources Board) victory. As I have stated before and will state again we still have a fignt on our hands. Here is what I see needs to be done:
Get the dealers to repair/replace without a On Board Diagnostic code being set, but replace on symptoms encountered by owners.
Get the part redesigned so the replaced part is a life of the car design.
Define whether the extended warranty is a once per car or for each ETM replacement.
But for now let's build up the data base.
Send an e-mail to [email protected] with ;
Your name
Your location, state and country
Describe briefly your ETM failure
Have you sent a complaint to NHTSA?
I now have about 300 in the list in 15 countries. When I send out e-mail I send your names as blind copy (Bcc) so no one else sees your address or can reply to all.
If you have not seen the TV reports you can at http://www.kmgh.com click on 'Iinvestigators' then on the Volvo story. To see the first report click on 'previous story'.
Don Willson for VEXED
[email protected]
http://VEXEDvolvo.org
Announcing my affiliation with XeMODeX, Inc. as Internet correspondent and consultant to Volvophiles needing help with failing ETMs. See http://FixYourETM.com. For the full history of this problem see http://VEXEDvolvo.org
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2857 times
Been thanked: 1332 times
Post by matthew1 »
Here's a direct link to the news story:
http://www.thedenverchannel.com/7newsin ... etail.html
I'd like to throw my effort behind Don's efforts by asking you to please get on Don's mailing list if you have a '99-02 Volvo and are affected by this problem.
It doesn't matter which country you're in or if you're not the first owner. Also, the original Volvo warrany has nothing to do with this. You should get on the list in any case.
Also -> Amazon link
