Just purchased 98 S70 GLT 145K on it. Had check engine lite on. After replacing a few items the CE would come and go. It was off so I was feeling lucky and went to the E-Check.
Put in before E-Check;
New Battery
Bosh plugs, Wires, Distrib cap and rotor
Replaced air and cabin filter
Bosh fuel filter
Ran a few tanks of 93 octane gas and fuel injector cleaner (pop & pour)
Drove it on highway for 20min
Took it for emisions test and failed.
Gas cap pressure good
Code P0302 cylinder #2 misfire detected
Code P0300 random/multiple cylinder misfire detected
What else could cause misfires like that? Ignition coil ?
Is there a code list somewhere on here?
Thanks in advance.
Code P0302 cyl #2 misfire & Code P0300 Multiple cyl misf
White850Turbo
- Year and Model:
It's the crappy Bosch plug wires; they all do that. Replace them with OEM Bougicord and you should be fine.
-Sean
1998 S70 T5 (Almost Stock)
I am having a similar problem. I'm getting an ODBII P0302 code on my car(listed in my sig). I replaced plugs, wires, cords, dist. cap and rotor all about a month ago. Just yesterday my check engine light came on with the P0302. The replacement parts I used are all listed in my sig as well. The plugs were supposedly pre-gapped to the correct specification. Should I try replacing the brand new plug wires as a previous poster mentioned or try something else. How do I tell if the spark plugs are funtioning properly? Shouldn't the bottom of them be gray-ish colored after a couple months use? Will a misfiring cylinder hurt anything? I haven't noticed any difference in performance or anything else. It is idling very smoothly and doesn't appear to be knocking. Please help!!! Thanks.
1998 Volvo S70 B5254FS 93k miles
Recently Replaced Parts:
Yokohama Avid H4S Tires
Bosch Platinum +4 Plugs
Bosch Plug Wires
Bosch Distributor Cap/Rotor
Bosch Front O2 Sensor
Front Engine Mount
Bosch Plug Wires
Front Engine Mount
the underlord
- Year and Model:
don't use platinum plugs..
just go get OEM plugs... that'll fix your problem.
thanks, anything else i should check for when i pull the plugs out? are the platinum +4's just bad plugs or my engine doesn't like em?
Bosch Plug Wires
Front Engine Mount
Bosch Plug Wires
Front Engine Mount
pfeener
- Year and Model:
- Been thanked: 2 times
+1 on everything that's been said. Stick with the genuine Volvo plugs and wires. Get the parts from FCPgroton. They have the Volvo plugs and the Bougicord wires are exactly what you would get if you walked into the dealer and pluncked down the big bucks. (and I mean exactly, right down to the stenciling and the Volvo brand name)
is there a plug i can get locally at autozone that will be similar to the stock volvo plugs? i'm not having any kind of black exhaust or anything and my car seems to be running better than ever so i dunno. it's an N/A car also, which i have read that the turbos have problems with the platinum plugs. thanks again for the advice guys.
Bosch Plug Wires
Front Engine Mount
Bosch Plug Wires
Front Engine Mount
how would i test the wires to see if they are operating to specification? voltmeter?
Bosch Plug Wires
Front Engine Mount
Bosch Plug Wires
Front Engine Mount
i picked up some ngk v-power. puh-puh-puh-puhlease help me with the other stuff.
Bosch Plug Wires
Front Engine Mount
Bosch Plug Wires
Front Engine Mount
- Has thanked: 17 times
- Been thanked: 35 times
People here have told you what to get and you go and get something else. What do you expect? The Volvo engines are finicky and don't like certain kinds of plugs. If you can't get the Volvo plugs for some reason, then you can use Bosch Copper plugs FR7DC. In fact, with an N/A engine, that's what I would recommend anyway. Bougicord wires (www.fcpgroton.com is your friend) too.
- 3426 Views
Last post by E Showell
- 11 Replies
- 2009 Views
Last post by greg850r
- 1649 Views
Last post by RickHaleParker
- 1711 Views
Last post by petermetzger
- 19 Replies
- 10204 Views
Last post by Barledge
