1999 V70R Fuel gauge innoperative
First Capital
- Year and Model: S60 T5 2002
My 1999 V70R has an inoperative fuel gauge. The miles to empty computer is also inoperative. Pulling the third seat and grounding the wire from the tank does nothing. What is the next step to diagnose the issue? Can the gauge in the cluster be replaced or does the cluster need to be sent out? What companies do repairs on the 99 clusters?
First Capital
One more thing, when the key is on the off position it goes down and when the car is started it goes to just under 12 gallons on the gauge.
First Capital
I just got an estimate from Volvo to repair the gas gauge, $2,665.00!
They said I need a new fuel tank sending unit to the tune of $1,525.00 and I have a shorted plate in the instrument plate in the instrument cluster that would cost $1,040.00 to repair!
egads
- Year and Model: S70 98 XC90 08 C40
Jesus-tapdancing christ! Time to talk to an auto electrician. They should be able to diagnose the components rather than through the computer and a fix should be much less than that. Hopefully others will chime in with specific advice.
polskamafia mjl
- Has thanked: 19 times
- Been thanked: 21 times
This may help although the 99's maybe different. Still worth reading over though. -> https://www.matthewsvolvosite.com/forums ... =1&t=57766
gooproduct
- Year and Model: 2001
Someone correct me if I'm wrong please but my understanding is that you have two fuel senders and both are wired together to send the level info to the gauge in the cluster. If one of the senders is failing you may only get an upper or lower reading only. I've had my share of sender problems on my '99xc. I know if you have access to Vida you can test your fuel gauges operation for a full sweep.
'77 242 GL (Traded for '77 Saab 99)
'82 245 GLT Wagon (Sold)
'88 245 DL wagon (Sold at 350,000 mi. still running great)
'89 244 Current
'89 740 GL (Sold)
'95 850 Turbo Wagon (Sold)
'99 XC70 Current
'01 XC70 Current
'89 244 Current
'89 740 GL (Sold)
'99 XC70 Current
'01 XC70 Current
gooproduct
After reading your issue again...you could have a stuck float. If the fuel sender has ever been tampered with, removed or replaced it must be orientated and locked in place or the sender float can easily get stuck in the tank and give a constant level that never changes. The gauge should, as you stated it does, drop to the bottom when the key is off.
'89 244 Current
'89 740 GL (Sold)
'99 XC70 Current
'01 XC70 Current
'89 244 Current
'89 740 GL (Sold)
'99 XC70 Current
'01 XC70 Current
