He feels like there may be too much junk in the engine from the flood that is causing it to not run well and backfire. Suggesting a new engine. Now I have always felt that an engine may be in the future. The question is do I take it to a good and expensive Volvo shop first is just drop an engine. I have a feeling that since he has none of the timing tools that I understand may be necessary, the issue may simply be getting the timing right. Any thoughts before I invest $2750?
Oh boy, what to do....
ohbucks
- Year and Model: S40 2007
Well, I took a chance with a flood damaged Volvo S40. When I received it it had a cracked oil pan, started but was blowing some white smoke with a rough run. Figured it needed a head gasket, got a deal on a new head so replaced the head and gaskets (yep, oil pan too). Was getting errors in cylinder 1 and saw that there was an issue with the gasket between 1 & 2. Put it all together and had some problems timing it and it backfires and is really rough. Now the tough part is the mechanic is a friend with nearly zero Volvo experience and I gave him the timing marks for the cams and crank.
- 2490 Views
Last post by Georgeandkira
- 1677 Views
Last post by Klausc
- 566 Views
Last post by volvolugnut
