V70 SE 2000 instruments/dash board not lighting up
JRL
- Year and Model: Several
- Been thanked: 16 times
Are the gauges working?
Not to sound obnoxious but did you somehow hit the thumbnail dash light dimmer?
If its not a fuse which you no doubt checked it 99% likely to be the LED lamps. is is just one ficture as in the heater control for example. I did a sinple search on E bay and found the right LED lamps they are a long style low voltage LED with a blue tip. Also try autoillumination.com
JRL
no LEDs in the dash. just several bulbs
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 20 times
Are the headlights/shift-lock working? If not, twitch the ignition switch a bit in the run position and see if they light up - this is a common problem with these cars.
'98 S70 T5
2016 Chevy Cruze Premier
JRL
It shouldn't be if the gauges are functioning
He has not come back and answered that yet
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
If some bulbs are out, you can follow these instructions to remove the dash pad.
- 1617 Views
Last post by wizechatmgr
- 1003 Views
Last post by Norm_B
- 4039 Views
Last post by WagonLagan
- 48 Replies
- 14369 Views
Last post by Rattnalle
- 1099 Views
Last post by hyllus
