1998 S70 T5 riding low-tires rubbing against wheel well
My 1998 S70 (210,000 mostly highway miles) appears to be sitting lower than normal. You can feel the tire hitting the wheel well when turning the steering wheel a few degrees to the right. Is it more likely the springs have sagged or the struts need to be replaced? Thanks.
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 20 times
Probably some of both. My struts were completely dead and the car sat close to the wheels, but not completely on them.
Unless you have oversized tires.
'98 S70 T5
2016 Chevy Cruze Premier
I took a closer look at the struts and noticed the right side bellows seems to have separated from the bump stop and the strut piston was exposed to the elements. I'm tempted to just replace the right side assembly to confirm that is the source of the problem. Or, is it wiser to do both sides since the older assembly might compromise handling? Thanks.
- 1250 Views
Last post by nirvana_1959
- 2556 Views
Last post by ppachsa1
- 1193 Views
- 2707 Views
Last post by oragex
- 12 Replies
- 3376 Views
Last post by RickHaleParker
