850 turbo EVAP hose
blazen244
Year and Model: 1995 850 Turbo
Post by blazen244 »
Is the hose from the fuel tank running straight to the EVAP canister? I found a hose hanging just behind the rear suspension link. Searched for the other side and found it running with the fuel filter hose. Is this a straight hose or does it connect to anything before coming to the front of the car?
Mr. 1000
1995 850 Turbo: IPD ECU, Big Bore intake and throttle body, Volan and cold air intake
2002 996 TT (X50) K24s, tuned to 500+ WHP
2003 GSXR 600 40th anniversary
2008 BMW 750 Li
2009 GSXR 1000: Full exhaust, K&N, PC5
2009 Cadillac EXT : 6.2/ 441 hp no need to tinker
jreed
Has thanked: 384 times
Been thanked: 221 times
Post by jreed »
If you could put up a photo it would help to be sure. Next to the fuel filter on my car ('97 850 GLT) there is a rollover valve that has lines connected to it. Could the loose line you described have become disconnected from the rollover valve fitting?
z2003
Year and Model: 2005 V70R
Post by z2003 »
I have the line (rubber pipe) broken. my question is: this line (broken) can cause any problem? or just waste fuel?
1996 850 T5
2005 V70R
