Hi, my speedometer and odometer stopped working. I replaced a steering knuckle last year and the knuckle was not from a 1998 as advertised on Ebay, so my abs sensor did not match.
However I installed the knuckle anyway since I accidentally destroyed that abs sensor while removing my old knuckle. To this day that front knuckle is missing an ABS sensor - I replace that sensor when I have time to pull that incorrect knuckle off.
I road with my ABS TRACS light on for several months without any problems, until I took my car in for a state inspection sticker. Upon leaving the shop I noticed my speedometer and odometer failure.
Before I spend $220 on a new ABS module, I'm wondering if any other parts can cause such symptoms - its a little suspicious that my problem began after leaving a repair shop. I opened my ABS module and the contacts looked decent, I soldered a few anyway, and my speedometer and odometer is still out of service.
Thanks for any advice
1998 S70 Speedometer and odometer quit
Matty Moo
- Year and Model: 850, 1996
- Has thanked: 1 time
- Been thanked: 30 times
The abs system uses both front wheel sensors to determine the speed of the car. It will still do it with only one wheel sensor but once you lose the signal from both it stops. You lost one automatically with the knuckle swap and the other dropped out from either the module being at fault or the sensor.
When you solder it, you have to hit both power pins feeding the abs pump and the bulk of the smaller 21 pins.
http://www.midwest-abs.com
Simplycleanpowerwash.com
1999 s70 Plain Jane.
2000 s70 GLT
2014 Ram
2012 Jeep Wrangler Unlimited
marcusheard
- Year and Model: S70 turbo, 1998
ok, I just installed a rebuilt ABS module that I purchased on ebay for $100, and my speedometer and odometer are still out. I'm moving on to my front wheel sensor next.
Does anyone know the ohms resistance for an ABS sensor on a 1998 S70? I'm thinking that since I only have one sensor connected up front (on passenger side), that one sensor must have gone bad (or there is a loose wire).
Thanks for any assistance
Matty Moo
You would be ahead of the game by repairing your unit properly, fixing the sensor and going from there.
2000 s70 GLT
2014 Ram
marcusheard
ok, after attempting to unplug my front wheel sensor from its harness the wires simply disintegrated - the sockets inside of the harness are practically glued in place by scale and residue. I just ordered a used sensor still in its harness for $35 and it will arrive next week. The last owner lived in Ohio, so its safe to say that my old car has been exposed to a lot of road salt.
- 12 Replies
- 543 Views
Last post by Chuck W
- 1959 Views
Last post by marcsanders
- 869 Views
- 1581 Views
Last post by Matty Moo
- 1986 Views
Last post by harryhendo
