1998 V70 T5 Need help with vac line routing
gmullen
Year and Model: 1998 V70 T5
Post by gmullen »
My main problem is this: The diagram sticker on my car and the web only shows two lines coming off the manifold but there is three lines not two. One is the fuel return, one to a check valve then purge valve but where does the third go to?
Here is a picture of the third hose?
Diagram showing only two lines?
1998 V70 T5
Has thanked: 311 times
Been thanked: 817 times
Post by erikv11 »
On my 98 V70 GLT, that line routes back to a nipple down at the base of the fresh air pipe, right next to the PTC.
gmullen
Post by gmullen »
Thanks!
1998 V70 T5
rmmagow
Year and Model: V70 1998
Been thanked: 2 times
Post by rmmagow »
Heh. I wonder if my V70 (AWD essentially a GLT with lots of added uselessness) has the line. It could trigger a p0171 if it were no good right? In an earlier post I was getting confused because I thought the connection I was looking at at the PTC was that line from the left side of the engine but I bet it is this turkey. Hope it's still light when I get home tonight.
1998 S70 135K - FOR SALE
2003 GMC Sonoma - 114K - POS
Post by erikv11 »
For clarity: the line from the left side of the intake manifold connects directly to the PTC, this turkey is a nipple at the base of the PTC. The one front and center here:
