Did you know? 🤔
2.4 in a 2.3?
How to go faster, stop quicker, and turn harder. Chips, exhaust, larger turbos, bigger/slotted/drilled rotors, high performance brake pads, manual boost controllers, performance shocks/struts/springs, airbox mods and more! Also discussion on HID and Xenon lights, aftermarket foglights and other exterior lighting.
Jockjunior
Year and Model: Volvo V70R AWD auto
Has thanked: 0
Been thanked: 0
Jockjunior
2.4 in a 2.3?
Post by Jockjunior » Tue Sep 03, 2013 3:50 pm
Hello I have a 98 Volvo v70r AWD, the engine has suspect head gone, I have a 2.4t5, will this run on the motronic 4.4 as a bolt in and go solution?
Jockjunior
Has thanked: 0
Been thanked: 0
Jockjunior
Re: 2.4 in a 2.3?
Post by Jockjunior » Tue Sep 03, 2013 3:51 pm
And then accept performance modifications?
jakegarrett
Year and Model: pv7 2012
Has thanked: 0
Been thanked: 0
jakegarrett
Re: 2.4 in a 2.3?
Post by jakegarrett » Mon Sep 09, 2013 6:34 am
I am also facing the same and just took my car to the service center. So just waiting for my car to come back.
Try to visit enamel bangle.
Year and Model: Lots
Has thanked: 4 times
Been thanked: 110 times
Australia
Re: 2.4 in a 2.3?
Post by precopster » Tue Sep 10, 2013 8:21 am
A T5 motor is a 2319cc engine with same stroke as the 2435cc engine but with smaller bore.
Therefore T5s are known as 2.3s .
Your R should be a 2.3 and the T5 also a 2.3. The detail is not in the motor itself but in the ECU and boost settings.
If you have a 2.4T or 2.4 LPT motor beware the higher compression ratio will result in overboost and detonation if not dealt with carefully.
Current cars:2002 XC70, 2006 Ssangyong Rodius (Stavic), 2006 XC90 2.5T, VW Transporter 2.5TDI
www.precisioncarmodules.com.
Jockjunior
Has thanked: 0
Been thanked: 0
Jockjunior
Re: 2.4 in a 2.3?
Post by Jockjunior » Fri Sep 13, 2013 6:52 am
Hi sorry didn't get my email to say anyone replied!
Mike what do you have to do to deal with overboost? I was thinking green injectors and a remap, the 2.3 is knackered but the 2.4 t5 I can get!
Does the 2.4 have vvt? Does this matter or will the motronic 4.4 run it?
Is there too much to do, should I source a 2.3, ultimately I want more power and thought the 2.4 would do this?
Thank you,
Scott.
