As are all the problems I've ever posted, here's a weird one: My wife reported the battery dead, so I took it to a store, had it tested, and yes, it needed a replacement. They had but one that would work, a T5, so I bought it for $125 (!).
I brought it home and noticed the posts were toward the front of the battery, not the back. That didn't seem too weird 'til I tried connecting the cables. They b-a-r-e-l-y would stretch out long enough to fit on the poles and I really had to work to get them on. When I hooked up the ground cable the motor fan started working.
I called the local parts store as a backup and yes--their batteries for the Volvo 850 have their posts at the front of the battery, too. Can someone help me make sense of two things that don't?
1. Replacement battery doesn't fit with existing cabling.
2. When I hook it up the engine fan comes and and the engine doesn't.
I thank you in advance!
1995 Volvo 850 Battery problem
- misha
- Has thanked: 152 times
- Been thanked: 402 times
1.Take it back and buy a proper battery for your carVTexan wrote: 1. Replacement battery doesn't fit with existing cabling.
2.Something is shorted...IF you didn't connect the terminals backwards( + on - & - on +) and fried something.
Proper battery for our cars is from 68-76ah.Anything below that will not last and anything bigger just will not fit at battery housing.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
Red-to-negative, black to positive. It's not on wrong.
Autozone checked and their replacement battery is the T5 in a different brand and that, too, has posts in the front. It's got a 3-year 100% replacement warranty, so it's not a cheapie battery.
- misha
I didn't said that it is a cheap battery....if the cables cannot reach the battery terminals,like you said....return it and buy a proper one.
I missed this:
Are you kidding me?
RED to POSITIVE & BLACK TO NEGATIVE!!!!!
You actually connected it backwards and...like i said...fried something!
I missed this:
VTexan wrote:Red-to-negative, black to positive. It's not on wrong.
Are you kidding me?
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
Rule #1: people who make television for a living and rarely tinker with their car...shouldn't. I broke rule #1.
Turns out I hooked up the battery backwards. Somehow in my mind I'd switched red and black (hand slaps forehead here)
Oh well. Now the battery cranks and there doesn't seem to be any fire. I'm guessing I burned something out there. I'll let the mechanic sort it out tomorrow.
- misha
You don't need a mechanic...you will need a good car-electrician!
Before you go to electrician...check the fuses.Maybe you will get-away with a few blown fuses,but your chances are really small.
It could be anything...from blown engine ecu to a blown fuse.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
difflock54
- Year and Model: V40 Nordic 2002
- Has thanked: 7 times
- Been thanked: 2 times
Perhaps resetting the ECU might do the trick? If your very lucky.
