IPD sale XeMODeX - Experts in Volvo Electronics
Get email notification of topic replies. Log in or register (free). Amazon Link Buy anything with this and it helps MVS!
1995 Volvo 850 GLT
Keep track of your Volvo's maintenance here. Keep track of what you did, when, and how much it cost.
Forum rules
Please create one topic per Volvo you own. Then simply post to that topic when you maintain or repair your Volvo. You'll have a nice record of what you did, when, and how much it cost. Only you can post in your topic.
Rbaratt
Year and Model: 850,S70,C70
1995 Volvo 850 GLT
Post by Rbaratt »
133,000 miles - 9/7/2013, New timing belt, idlers, tensioner and water pump. Replaced spark plugs, ignition wires and serpentine belt. Cooling system refilled with new Volvo coolant. Drained 3.5 quarts of of original ATF and re-filled with new ATF (Toyota Dexron III).
2008, C70, 44,000 miles
2000, S70, GLT, 67,000 miles
1995, 850, GLT, 144,000 Miles
1996, 850, Turbo, 226,000 Miles (TMU)
Rbaratt
Re: 1995 Volvo 850 GLT
Post by Rbaratt »
9/15/2013 - PCV service completed. The service successfully corrected the smoke from the dipstick and it no longer blows up the glove placed on the oil fill port.
Rbaratt
Post by Rbaratt »
10/5/2013 - Replaced rear brakes, pads, rotors, R/R right rear caliper (Used). R/R right rear brake pipe (right caliper to flex line), flex line and center brake pipe (flex pipe to left rear junction). Bled rear brakes.
10/5/2013 - rotated tires. Same side front to rear.
Rbaratt
Post by Rbaratt »
12/7/2013 - lost all coolant while driving home from my neighbors house (1/4 mile). Found lower hose clamp snapped (rust) and lower hose off of radiator. Replaced clamp and re-filled with Volvo coolant.
Rbaratt
Post by Rbaratt »
3/28/2014 - R/R turn signal switch with donor part. Pick and pull charged me $26 for the part. I thought that was steep since a new one from eeuroparts.com is $87.
Rbaratt
Post by Rbaratt »
5/10/2014 - new Bosch o2 sensors (front and rear). Front o2 came out with a little effort and Pb blaster, the rear was a different story. Exhaust shop welded in new Magnaflow cat with a new pipe and o2 bung. Waiting to see if po133 code comes back
Rbaratt
Post by Rbaratt »
5/11/2014, Replaced front engine mount with Lemforder mount. LOF with Mobil 1, Mann filter, 10w40, replaced oil cap o-ring. Recharged A/C, no a/c system leaks found.
Rbaratt
Post by Rbaratt »
6/20/2014 - R/R fuel filter (Bosch)
Rbaratt
Post by Rbaratt »
11/22/2014 - R/R battery. $100
