Hi All, Last 5 years. Red 95 850 na bought at 125K miles, seller said he put new timing belt, pump etc. I've owned Red 5 years now. Paid $1455. $300 Maaco paint job
Replaced : light bulb in gear selector and ashtray ($4), headlights, (2 maybe $40 from walmart), radiator($140), coolant reservoir tank cap($5), starter & solenoid as one unit($120), battery($60), Spark plug wires $30 (diy ers), Rotor & dist. cap ($60), 4 battery cable terminals ($15), positive battery cable($10), fuel pump ($50), AC dryer ($1200 Viking Volvo rip off), serpentine belt($30), ($15~glove box lock, trunk lock assembly-), flushed transmission, transmission lines clips ($105), ($38)brake pads, ($5)anti-sway bar end link (1),($10) S70 wood shifter knob. ($36) Used blower fan motor and resistor. Ash tray & supporting mechanism ($8), AC recharge Duracool (great stuff $80),($5) lighter socket, fuel & oil filters. left turn signal($25),($120) passenger side lower engine mount bushing? Driver's side window ($40), Driver's side window regulator ($40),Cruise control switch at foot pedal and under battery tray ($25), MCC unit LKQ ( 25), mcc vent position switch (rip off Viking Volvo),2 cup holders $6, jack $10, Both CV axles Sept. 2013 ($105 Oreillys) as of Sept 2013
Sept 18, 2013($22) Installing driver incline seat electric motor & cable, lighter socket. Trying to fix mcc swith to change air routing positions.
Up soon --- PCV hose and parts. and Clean IAC, MAF. Replace plugs, wires, rotor and dist. cap.
Have the parts for the timing belt kit ($ 230) ~(not yet installed),
Lining up parts & instructions with pictures heater core & hoses
Still to go ~~~~ Horn fix. Cruise control trouble shooting. Hopefully just the AC compressor (LKQ $51)and sunroof(flips up but will not go back) to go (LKQ $120), then Hood and another $300 paint job. Full size spare tire, right turn signal light in dash.
BLUE 95 Volvo 850 na bought at 170K miles. 4 new tires $336, positive battery cable $30, blue flame shifter knob cover $11, S70 wood shifter knob $10, trunk struts $10, cup holder $3,
fixing driver side incline, cable or cable repair, at some point Sept.19, 2013 Have to fix mcc vent position switch. windshield leak sealer
Up soon or: PCV and Timing belt ~ water pump, hydraulic tensioner, serpentine belt, timing belt, fixing driver side incline, cable or cable repair, at some point evaporator /drier, Duracool recharge,etc Put in 2 AC cans, lasted 20 minutes or so. Needs light in clock temp dash.
Red 95 850na
Forum rules
Please create one topic per Volvo you own. Then simply post to that topic when you maintain or repair your Volvo. You'll have a nice record of what you did, when, and how much it cost. Only you can post in your topic.
adventurer2112
- Year and Model: 95 850 na
- Been thanked: 7 times
