p0410 97 960 question
Hey I have a 1997 960 that is throwing the p0410 code. I checked all the fuses and relays and they are all fine. However the pump itself is not getting voltage....It will work if i jump it directly from the battery. Can anyone help me as to where the next place I should look? thanks.
- Has thanked: 1613 times
- Been thanked: 4077 times
Discussion of the P0410 code (Secondary AIr System problem) is here
https://www.matthewsvolvosite.com/forums ... php?p=8952
Yes I did as much research as I could before posting. But none of that discussion helped. I am trying to get voltage to the air pump. The relay and fuses are good. Pump works when jumped... Will there only be voltage on start up? Thanks
lindy8_man
- Year and Model: 1998 S90
Check the control valve. There should be vacuum hoses coming out of then connections to the ECU.
Beer and DIY Volvo Repairs are proof that God loves us and wants us to be happy.
- 1050 Views
Last post by benpineapple
- 25 Replies
- 5953 Views
Last post by Gerd
- 13 Replies
- 2449 Views
- 772 Views
- 1733 Views
Last post by FLXC90
