1991 240 Engine misses and shakes at idle when warm
injection
Year and Model: 1992 volvo 240
Post by injection »
My dad's 240 when the coolant temp needle gets to the middle the engine has a bad habit of violently shaking but when the engine is cold it runs smooth.
What's been replaced: intake gasket, spark plugs/wires/dist, fuel filter, coolant temperature sensor, cat, and the harmonic balancer.
What's been checked: injectors, TPS, and ignition coil.
Any help is appreciated.
lindy8_man
Year and Model: 1998 S90
Post by lindy8_man »
Generally for what is left, I would test at your MAF, verify timing, and check your motor mounts.
You would do well to also narrow down the problem to Air, Gas or Spark. then trace back from there.
Beer and DIY Volvo Repairs are proof that God loves us and wants us to be happy.
Richard-Bundy
Year and Model: 940 1992
Post by Richard-Bundy »
hi,
if you haven't already checked it, try the idle air control valve. if its not the problem, cleaning it wont hurt. my sons 940 had all sorts of rev control problems until the IACV was cleaned. also it wouldn't hurt to clean inside the throttle body. the other 2 things I found are common , are a dirty MAF ( easily cleaned with MAF cleaner or circuit cleaner ), and a stuck flap at the airbox entry. I just temporarily fixed one by making some holes and zip tying the flap in the cold intake position.( I live in a warm climate). when I get a chance I will totally remove the flap and cover the hot air duct hole.
all the best !
rgk
Year and Model: Gray 88 245
Has thanked: 1 time
Post by rgk »
I second the idle air control valve. It's at the driver's side of the engine, underneath the intake, and has two vacuum and one electrical wire running to it. It's a small cylindrical object.
rgk -- was dickdeadly
rgk
Has thanked: 1 time
Post by rgk »
I would also check the coolant temperature sensor.
