2000 S70 GLT Any Tricks To Replacing O2 Sensor
warcoy99
Year and Model: 2000 S70 GLT/SE
Post by warcoy99 »
BESIDES UNCLIPPING AND UNSCREWING SENSOR THAN REPLACING?
Changing w/ bosch #17070
does the check engine light go off after replacing and starting?
Reason: Lowercased title, please no ALL CAPS in titles. Review forum rules.
WARCOY99
HOOK 'EM!
precopster
Year and Model: Lots
Been thanked: 128 times
Post by precopster »
Reading fuel mixtures happens straight away so code will disappear once the new O2 sensor is plugged in.
This is assuming the O2 sensor itself was causing the 02 light.
misha
Has thanked: 155 times
Been thanked: 432 times
Post by misha »
You will need Denso O2 sensor for your car,
not Bosch.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
Has thanked: 1611 times
Been thanked: 4075 times
Lots and lots of PB blaster applied over 2-3 days, don't drive car in between
mikealder
Year and Model: V70 2000
Been thanked: 13 times
Post by mikealder »
If the car doesn't have a turbo you can fit a Denso DOX-1419 as that is what it had fitted from new, these can be found slightly cheaper than the OEM probe and the only difference is the box it is supplied in.
I fitted one of these to my V70 N/A engine MY2000 just under two years ago and it has been fine ever since - Mike
