IPD sale Volvo Parts
2003 V70 D5 - swapping a BCM for a used part
Help, Advice, Owners' Discussion and DIY Tutorials on Volvo's stylish, distinctive "P2" cars.
2001 - 2007 XC-70
Year and Model: Lots
Has thanked: 3 times
Been thanked: 38 times
Australia
Re: 2003 V70 D5 - swapping a BCM for a used part
Post by precopster » Mon Oct 14, 2013 10:43 am
How did you come across the solution? Did you keep swapping BCMs until software numbers matched or was there another fix?
Current cars:2002 XC70, 2001 V70 T5, 2006 XC90 2.5T, VW Transporter 2.5TDI
www.precisioncarmodules.com.
bigbrain
Year and Model: v70 D5 2003
Post by bigbrain » Mon Oct 14, 2013 4:48 pm
Basically I think it's a game of roulette...I went through 4 units unit/£300 before I got a match....still cheaper than the £1,000 quote from the indie which would have written my car off...it was a bit of a gamble but at least you know it is possible...everyone I spoke with said the units were individually locked to each car.
rubbersidedown
Year and Model: V70 2001
Post by rubbersidedown » Thu Sep 04, 2014 11:55 am
I have just replaced my DSTC ABS/BCM p/n 8634413 and all errors and typical misbehavior are gone. The used module I put on must be a little different in its SW config as I get a DTC BCM 0076. So, my independent says he can do SW reload for about $130. I have seen the SW advertised for about $50, http://www.volvopartsdept.com/OEMParts/ ... 82705.html.
Can I do this myself with my China VIDA DiCEpro? Anyone successfully tried that, if how is it done?
Car is -01 V70 T5. Cheers.
dczech
Year and Model: 2005 s60r
United States of America
Post by dczech » Tue Jun 12, 2018 6:25 am
Sorry to revive an old thread, but were you able to program this bcm to your car?
I have replaced the bcm on my 05 s60r. Same part numbers on units. Not sure how to read the software versions.
Got rid of (intermittently at least, possible sensor failing) the abs light, but still Getting anti- skid service required.
Australia
Post by precopster » Thu Jun 14, 2018 6:29 pm
You need Vida to read off old vs new software versions in Network menu.
If your replacement is a used unit it is more than likely requiring repair and/or resoldering
JoseBorch
Year and Model: 2001 v70
Norway
Post by JoseBorch » Tue Oct 09, 2018 1:54 am
Tried the same with my v70 secon gen. I got a used unit an checked with volvo that partnumber was the same and it suppose to fit my car. I mounted it then got this bcm0070 code instead of earlier codes. It means that the car doesnt correspond with the used unit because it has been fitted in another car earlier. Its not possible to put new program in it cause the brand new unit programs it self when fittet to each car. The also told me i had to get a brand new unit that cost like 2 thousen euros at least. Thats really f.up for bcm that volvo knows its bad. Its a known problem that they malfunction. Only thing i could think of would vork it to swT the chip /transistor that contains the programming from the original one to the used one. But who would know widge it is???? I would really like to know that.
JoseBorch
Norway
Post by JoseBorch » Tue Oct 09, 2018 1:56 am
Swap the chip that contains the programming
Australia
Post by precopster » Tue Oct 09, 2018 6:37 am
No contact Doublebug (contributor to this thread) or his associate in California (Yagger) and they can read old sw versions using your Dice unit over the internet and clone another BCM if it has the same part number (most of them end in xxxx2216)
They have done BCMs, ECMs, ETMs and CEMs for me on a number of occasions and they do great work
Who is online
Users browsing this forum: chrism, Google Adsense [Bot], mrjay62 and 32 guests
