Crankcase vent hose connection problems
reptar
Year and Model: 850, 1996
Post by reptar »
Having installed new crankcase vent hose (#9125598) on oil separator, I am having difficulties aligning the bayonet hose connection to the air supply hose (#9141229) on the inlet manifold. Can anyone help me as to why I am having these problems. Please see attached photo.
The car I am working on is a Volvo 850 NA non turbo B5252S.
rspi
Has thanked: 34 times
Been thanked: 72 times
Post by rspi »
Can't really tell. Did you get it pinched under the intake manifold? Or, did you connect it on the wrong port at the oil box? Is should be on the front/closest port. Many photos show it on the wrong port.
reptar
Post by reptar »
The crankcase vent hose is connected to the closest center port. After close inspection, the hose air supply #9141229 apparently does not fit my VIN. Apparently the hose air supply part that fits my VIN is #9179301. Can anyone tell me the difference between these two parts? Perhaps this is why the bayonet lugs are not able to rotate properly to engage correctly.
reptar
Post by reptar »
Can anyone tell me if there is a difference between these two part numbers?
#9141229 and
#9179301
I would like to know if the lug locations are in different positions? My problem is that my breather pipe #9125598 (correct for my VIN and engine number) will not engage correctly into the lug holes of the air supply hose #9141229 and was wondering if someone knew whether the lug holes of air supply hose #9179301 where aligned slightly different to allow me to engage my breather pipe correctly?
