I am about to swap the Upper Stabilizer Bar Engine Mount. The bolts are very firm and seem to require a fair bit of grunt to get them to move. I am reluctant to put too much into it for fear of breaking something.
So the question is is there any way I could make their removal easier? I am thinking of the ol' Penetrene/WD40 but I am not sure it would be successful or even wise.
Another question whilst I working in that area, relates to the the Mounts at each end of the bar. Should they have any wobble or should they be fairly stiff? I can grab the bar and move fairly easily which is made easier by the fact that the other Mount is not doing its job properly.
I am of the opinion that because the car has done most of it travelling in the city, the stop/starts and the flexing that puts on components would cause them to wear more quickly. The car has only done 49,000 miles.
2002 V70 Upper Stabilizer Bar Engine Mount Bolts Topic is solved
- MoVolvos
- Has thanked: 312 times
- Been thanked: 525 times
Is this the correct Parts Diag? Enlarge the Diag.
http://www.volvopartswebstore.com/showA ... bly=237561
kymg
- Year and Model: V70 X Country 2002
Thanks BKM - it is not the correct diagram.
The bit that I am to replace is the B2544 equivalent of Part 13. This diagram is for a Diesel engine I think. I have the petrol job.
The other bit I referred to later is Part 2
Cheers
Cheers
kymg
Well I did my Stabilizer Mount this afternoon. Bloody snap to do - took me about half an hour from go to woah - tools out to tools packed away. The other mount was buggered - split and looking very sad for itself. Question - is it worth keeping the bracket and buying the rubber mount that goes inside for next time?
Now I suspect that the outer mounts have given up the ghost too and will need to be replaced.
I mentioned in an earlier post that I had a rattle in the back of the car, Well it would appear that I am otically dyslexic because my son said "Dad, it's coming from the front". So I suspect that I may have fixed my rattle. Life is good.
kymg
Well replacing the Upper Stabilizer Bar Engine Mount did not fix the clunk.
So here are the symptoms:
The clunk does 'feel' as though it is towards the rear of the car. I thought it was at the front.
It does not occur when the car is cold and appears after the car has been driven for a while. It is as if the bits that clunk have softened a bit and therefore prone to movement.
It occurs when I go over bumps.
It does not occur when I accelerate or brake.
So any thoughts would be much appreciated.
Cheers
Cheers
LASteve
- Year and Model: 2015 V60 T5 E-Drive
Check your strut mounts and sway bar end links. These are very "clunk-prone" when they start to wear out.
Current Sled: 2015 V60 T5 E-Drive
Volvos I used to own:
02 V70XC
99 V70XC
97 855 NA
87 245 DL
02 V70XC
99 V70XC
97 855 NA
87 245 DL
- 10212 Views
Last post by SuperHerman
- 1279 Views
Last post by Mandude
- 47 Replies
- 7868 Views
Last post by jantt
- 1433 Views
Last post by hu5ker555
- 1234 Views
Last post by jeffsws
