Did you know? 🤔
Best method for turbo reinstall? 2004 V70 awd
How to go faster, stop quicker, and turn harder. Chips, exhaust, larger turbos, bigger/slotted/drilled rotors, high performance brake pads, manual boost controllers, performance shocks/struts/springs, airbox mods and more! Also discussion on HID and Xenon lights, aftermarket foglights and other exterior lighting.
686 Sport
Year and Model: 2004 V70 2.5T awd
Has thanked: 0
Been thanked: 0
686 Sport
Post by 686 Sport » Sat Oct 05, 2013 1:19 pm
With Lucky's help, I have acquired a flashed ECU and 16T housing with billet wheel for my 04 V70 2.5T AWD.
When removing the turbo I left actuator and cartridge attached to the flange and pulled the entire assembly. This was a bit of a hassle.
Can anyone here suggest the easiest way to reinstall? I'm inclined to follow this order:
1. bolt flange to exhaust manifold
2. clamp on the cartridge /compressor assembly finger-tight
3. connect oil, water, and air lines
4. bolt up exhaust downpipe
5. attach wastegate actuator
Since no one is at ARD today and Lucky is out next week, can anyone recall or link to the initial setting for the ARD wastegate actuator?
Tips on when and how to fill the cartidge with oil would also be appreciated!
tia,
686Sport
