Hello again Volvo enthusiasts !
My wife's 95 850 glt N/A 20 valve cranks but wont start.
so far i have determined that there is SPARK between the coil pack and primary ignition wire.
I have also observed a fuel smell after cranking.
There are no related codes from the OBD 2 connector with code reader.(haven't checked under hood diag boxes yet.( battery was disconnected so not sure I will find any).
would a faulty Cam sensor cause NO SPARK condition? AND, what happens exactly in Volvos when there is a faulty CAM Sensor? How does the ECM react with bad Cam Sensor?
I hooked up spark tester light between coil pack and primary IG wire, and the light was orange in color, it was lighting up. but I thought it looked a little dim, ..it could just be my cheapo test light though.
Does anyone agree that it sounds like I have a simple Faulty Distributor Cap & Rotor Issue?
Thank You.
1995 850 GLT Wagon , Engine Cranks but will not start
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
Check spark at the plugs, make sure you have fuel, if both good, check compression.
nine5Volvo850
- Year and Model: 1995 850
Were you able to come up with a solution? I am having the same issues with my 95 850
- Clemens
- Has thanked: 498 times
- Been thanked: 228 times
There ia a no start flow diagram posted in the sticky section. Sometimes these cars get flooded so badly you have to pull the pligs and?crank them really long (a few minutes) with the fuel pump fuse pulled (so no fuel enters?the cylinders). Might do the trick.
And use the OBD blinky box if it still refuses to start.
1996 855 R,
2010 V70 D5,
2010 V70 D5,
- 961 Views
Last post by seattle850
- 32 Replies
- 4948 Views
Last post by MadeInJapan
- 965 Views
Last post by Ozark Lee
- 188 Views
Last post by misha
- 4396 Views
