I made a couple tools today.
First an idler wrench. Picked up a piece of 1 inch piece of 3/4 bar stock, and 18 inch piece of 3/4 x 1/4. Welded the the bar to the end, ground it a little to fit. Works fine, as good as the online for $29.
Second, made a Cam gear locking tool. I started with card board, and pressed it into the two cam gears, enough to leave an impression. Then pushed nails through where it looked right. Test fitted the cardboard/nails and looked ok. Next transferred the holes to a block of wood and drilled. Next I inserted the nails. Test fitted, and the four nails messed into the cam gears. I had a piece of scrap aluminum, so i transferred those holes, drilled 1/8 for the cut off nails, and JB welded the nails to the aluminum. Works fine. Its a knock off of the online tool available. I could have stopped with the wood version, it looks like it would work as well as the aluminum, but I had the scrap metal, and the time on a rainy day.
96 850 GLT Home made tools
joe_pinehill
- Year and Model: 850 1996
96 850 GLT
RIP '90 240 DL, 285K, someone ran a stop sign in front of me
RIP '89 760 Wagon, 200K
RIP '83 240 Wagon, rusted out
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
Nice work. Please polish them smooth, power coat them and I'll send you $20 for the pair.
Just kidding. I have no welding skills or equipment.
- jreed
- Has thanked: 384 times
- Been thanked: 221 times
Nice tools! I admire the idler pulley wrench especially. I'll have to post up a picture of the "tool" I made using a scrap of square aluminum bar, a wrench and some duct tape. Mine's not as nice as yours!
QuirkySwede
- Been thanked: 12 times
No welding needed. Just a trip to your local hardware store.
DIY: Serpentine Belt EZ-Tool (<$2) & Routing
https://www.matthewsvolvosite.com/forums/viewtopic.php?f=1&t=60913
A photo from that thread (visit for more):
- 16 Replies
- 4926 Views
Last post by vtl
- 2750 Views
Last post by matthew1
- 1978 Views
Last post by esl_97_850_T5
- 1226 Views
Last post by loveMy850
- 41 Replies
- 6857 Views
Last post by E Showell
