I have a 2011 volvo c30. My question is will a 2011 volvo c30 E-code headlights with auto level motor be able to work on a US volvoC30? The E-Code headlight uses H-7 bulbs where the US-DOT headlights use H-8 bulbs? My 2000 s70 has the e-codes and all i had to do was remove a wiring harness and put the headlights in. Does this ring true for the C30? Also can i bypass or set the auto level and then never use it or even adjust it manually?
WHAT DO I NEED TO DO TO MAKE THIS SWAP WORK?
2011 EURO Headlight swap question?
