I pulled this code from my 2000 S70 Base model. I am unclear on what needs to be replaced.
P0443: Evaporative emission system (EVAP) valve.
I'm thinking perhaps it is the evap canister purge valve? Or the Canister shut off purge valve? They are two different parts.
Anyone else had this come up?
2000 S70 Base P0443: Evaporative Emission System Code
UPDATE: I've replaced my EVAP Vapor Canister Purge Valve (9470775). Cleared all the codes. Have cleared codes and driven the car several times, still getting this P0443 code. I checked the connector, and it is good, clips into place, no corrosion. What gives?
I've searched and searched and searched. Apparently myself and one other guy with an earlier model 850 are the only two people on earth who have ever had a car throw this code.
The hose on top of the tank might be leaking. Reference this thread to maybe isolate that issue:
https://www.matthewsvolvosite.com/forums ... =1&t=60269
ugh smh 850 Turbo fridge
- 1348 Views
Last post by rmd62163
- 1005 Views
Last post by 93Regina
- 896 Views
Last post by mnmk
- 2497 Views
Last post by nyc1836
- 2291 Views
Last post by RickHaleParker
