99 s70 2.4 , Small coolant leak radiator !
nonturbo
Year and Model: S70 / 1999
Post by nonturbo »
Hey guys , 99 s70 2.4 , small coolant leak radiator ! Don't believe its coming from the tank seal... It drips about a 6 - 12 oz's overnight , and is intermittent . Thinking of using Bars Aluminum Stop leak or Prestone super aluminum stop leak with the Kevlar particles . Any recommends for temp fix !!
JDS60R
Been thanked: 3 times
Post by JDS60R »
Best to just pull it and drop in a Nissens from FCP. Temp fixes cause an even more expensive issue about 20% of the time. Sometimes after the rad was replaced as tech did not flush the system to get the particles out.
Your call
Best Wishes,
John
Retired
rspi
Has thanked: 34 times
Been thanked: 72 times
Post by rspi »
Replace the rad or the hoses. Figure out which is leaking.
Don't play coolant roulette. It's not worth it.
nonturbo
Post by nonturbo »
Saw the leak dripping from passenger side near the tank, not sure it's the tank... no $$ for radiator now, have to replace later.
Has thanked: 1614 times
Been thanked: 4078 times
Just remember the stop leak product means 2000 USd for head later.
rspi
Post by rspi »
nonturbo wrote: no $$ for radiator now, have to replace later.
Then park it. This means that you can't afford to drive. Radiators at a salvage yard are about $40. There are a lot of them in there that are good and some that are newish.
nonturbo
Post by nonturbo »
ok, ok, I get it "no stop leak" !! Found used one for $75 , I have to drive 45 miles to get it ... 8)
ericbs1975
Year and Model: S70 GLT, 2000
Post by ericbs1975 »
I replaced mine a couple of weeks ago. Got one new off ebay for about $80 (including shipping). Mine had a crack in the seam on the plastic side of the radiator on the passenger side. It's not too bad of a job. I did it in a few hours and I am a horrible mechanic. If you poke around a bit, many will recommend you replace the green clips and o-rings for the transmission cooler lines where they connect. I'd agree with them, the green clips get real brittle and if they crack you could have one pop out while under pressure. Here's a link to the kit from IPD: http://www.ipdusa.com/products/5777/114 ... l-kit-1999
nonturbo
Post by nonturbo »
Thanks eric ! FCP has new one for $175 free ship... Did they have any more rads on ebay ?
ericbs1975
Here's this one: http://www.ebay.com/itm/BRAND-NEW-QUALI ... aa&vxp=mtr
Do your due diligence and see if there are any reviews. These guys seem legit, and it is warrantied. $80 shipped isn't too bad. Mine was similar and seemed pretty solid, but your mileage may vary.
