I went out to my car this am and it was about 40 degrees (farenheit for our non-USA folks) and wet. When I put the key in all of the lights on the dash went on and the electrics were otherwise normal, but when I turned the key to start the car I could hear some tapping and clicking from various places under the hood, but no cranking at all. I tried disconnecting and reconnecting the battery to no avail. I plugged in my code reader and no codes.
Of note over the past year or so occasionally when it's wet out the code for the CVVT sensor (1332, if I recall correctly) and I'll clear it and it won't return. Otherwise the car runs fine. I replaced the fuel filter about 6 months ago as well, so I don't think it's that. I'm not by the car at the moment so I haven't listened for the fuel pump, but I'd imagine that it would try and crank even if the relay wasn't functioning.
Any ideas where to look?
Thank you,
Aaron
1999 V70XC No crank with cold wet morning
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
Dead battery. Try to read volts while cranking.
- 1517 Views
Last post by darrylrobert
- 673 Views
Last post by sane
- 3486 Views
Last post by Empathron
- 1039 Views
- 376 Views
Last post by JimBee
