1999 s70 t5 timing belt
my s70 t5 has the hydraulic tensioner timing belt but all the listings at the autoparts seem to be with the mechanical tensioner because my car was made before a certain date. would I be safe to get the full kit from a 1998
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 20 times
Are you sure it is a 1999? Is there a VVT actuator on the exhaust cam or an electronic throttle body?
'98 S70 T5
2016 Chevy Cruze Premier
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
Run your VIN at www.AutoCheck.com and see what comes up.
i was considering doing the timing belt because even though it is about 40 000km away from needing to be done it has been sitting for a year without running, i took the cover off and the belt looks good with no cracks and some real miner rust on the pulley surfaces but it makes no bearing noises or anything so i think i will hold off till i get some extra cash in the bank and do the full job in the spring with all the seals and water pump. i only do about 10k km a year .
- 5497 Views
Last post by jimmy57
- 23 Replies
- 18218 Views
Last post by jonesg
- 20 Replies
- 17843 Views
Last post by Hurtfeelings
- 1519 Views
- 1628 Views
Last post by kmg108
