Did you know? 🤔
2000 V70 XC AWD Rear Differential Fluid change
bobice
Year and Model: XC70 1999
Has thanked: 0
Been thanked: 0
bobice
Post by bobice » Sun Nov 10, 2013 2:49 pm
Hi,
My 2000 V70 XC AWD at 195,000 miles has some noise from rear differential for 4 years/30,000 miles now. My shop said it is bad and replacing would cost $1500 4 years ago, thus I didn't have it replaced. Since the car drives fine, and I would like to try to "fix" the noise from differential for better driving experience. Some members pointed out that loss of differential fluids could cause the noise, and maybe changing the fluid can also help. Anyway, is it true that the differential fluid shall be changed regularly?
I climbed down my car and checked the rear differential. It seems that there is one screw at the front of the rear differential on the driver side. I could not find any other plugs, is this screw the plug that I need to take it out to replace the fluid? If I to get a Volvo fluid, what's the part no.? Or what's the good alternative? I attached a picture here.
I also checked the post here, http://www.matthewsvolvosite.com/forums ... =9&t=30663
But it is for the 2nd generation v70. It looks very different from mine.
Thank you in advance!
MilehighV70XC
Year and Model: '99 V70XC, 143,000mi
Has thanked: 0
Been thanked: 0
MilehighV70XC
Re: 2000 V70 XC AWD Rear Differential Fluid change
Post by MilehighV70XC » Sun Nov 10, 2013 6:36 pm
Yes that is the fill plug. I am pretty sure you either use Volvo brand fluid its cost like $25 or GL-5 75w90 full synthetic. Searching on this forum will produce the answer but i am pretty sure that is what it takes. It should be in your owners manual also.
http://www.matthewsvolvosite.com/forums ... =1&t=23189
bobice
Has thanked: 0
Been thanked: 0
bobice
Post by bobice » Mon Nov 11, 2013 8:58 pm
Thanks! I bought the Volvo rear differential oil from FCPeuro, mineral based for $19. Will try and see whether the fluid change will help.
bobice
Has thanked: 0
Been thanked: 0
bobice
Post by bobice » Sun Nov 17, 2013 4:04 pm
After getting the Axle Oil (1161620) from FCPeuro and a multi-purpose pump from Harbofreighttools ($6 after coupon), I added 600 ml of oil to my rear differential. All old oil must have leaked. Will report back if the noise goes away a few miles later.
Richard99
Year and Model: 2000 V70XC
Has thanked: 2 times
Been thanked: 0
United States of America
Richard99
Post by Richard99 » Sun Jan 12, 2020 9:37 pm
Did this solve your noise problem?
Eric
1998 Volvo V70
2000 Volvo V70XC
shiloh51933
Has thanked: 11 times
Been thanked: 7 times
shiloh51933
Post by shiloh51933 » Thu Jan 16, 2020 12:20 pm
It must have a slow leak if it was low...did it resolve your issue?
If U Wanna Play U Gotta Pay!!
