Hi fellow members
I recently purchased a manual S40 2.0T and everyone who has driven this car in my family have stalled it at low speeds. It's a gentle stall in that it only happens at low speeds ie in traffic or car parking.
When the clutch is re-engaged, the revs dip to a point where the call "gently" stalls. In order to prevent this from happening, the clutch has to be engaged with a slight blip or riding of the throttle to keep the car running.
Stage 0 maintenance has all been done and the car pulls nicely with no issues. No codes.
I have a S40T4 manual as well and that one doesn't do what the 2.0T does.
Any ideas?
2001 S40 2.0T Revs drop & stall @ low speeds
difflock54
- Year and Model: V40 Nordic 2002
- Has thanked: 7 times
- Been thanked: 2 times
What rpm's does the tach show when car is idling in neutral?
Should be about 750-800rpms.
Your idle may be set a bit too low such that when the clutch is depressed the increased load on the engine allows the engine rpms to drop enough for it to stall.
- 28 Replies
- 12236 Views
- 1731 Views
Last post by TheCynicalCanuck
- 21 Replies
- 11619 Views
- 12 Replies
- 3818 Views
Last post by jvl
- 647 Views
Last post by volvolugnut
