the weather has changed here now in Canada ..... winter .... its getting a little colder and ive noticed a vibration between 45 - 60 km/hour .... its worst at about 50 and seems to almost jar the car. if you are under 40 or over 60 its fine ... no vibration and drives straight.
i'm thinking maybe engine or tranny mount .... any advise ??
1999 V70 awd vibration at 45 - 60 km/h
mfagus
- Year and Model: 1995 850 Turbo wagon
Had same issue on another car, go to a tire shop and have them check the tires and see if they are properly balanced. A weight might of come off and the symptoms you describe are exactly what i had.
0-45 MPH, no vibration, 45-60 vibration, 60+ no vibration.
wheels balanced, problem solved.
Mark
Mark
- Been thanked: 4068 times
My V70 would go resonant at 40 mph if I had any window down by a cm or two...make sure that's not it!!
rmcmighty
- Year and Model: 1999 V-70 XC
Today i took the car into the tire shop and had 4 new tires put on the car as well as having the wheels balanced ..... drove the car out of there and thought id take it for a little spin and see if the vibration was gone? drove for a bit to get the suspension moving around and stuff .... after about 5 mins of driving the vibration came back, seems to only do it once you are driving for a couple mins and then every time you hit 45 - 60km per hour the whole car vibrates ..... could it be a Ujoint or something else?
I've tried getting it up to 50 and slipping it into neutral .... still vibrates ... no change
maybe engine or transmission mount
- phils94850
- Year and Model: 2009 s60 turbo
could be a bad cv axle
1996 Platinum Edition
rmmagow
- Year and Model: V70 1998
- Been thanked: 2 times
Propshaft for the AWD. I don't know how to check it but my 98 AWD started doing this and taking out he propshaft fixed the vibration. Before going nuts, have it removed and see if the vibration goes away.
1998 S70 135K - FOR SALE
2003 GMC Sonoma - 114K - POS
rmcmighty
i will be removing the propshaft this evening, i changed out a bad cv shaft and it didn't fix the vibration.
I found a great link with detailed instructions on removing and reinstalling the propshaft though
http://www.swedespeed.com/artman2/publi ... epair.html
Enjoy
Enjoy
- 392 Views
Last post by wuttheheeck
- 36 Replies
- 7361 Views
Last post by 850 LPT
- 1883 Views
Last post by rspi
- 1153 Views
Last post by JRL
- 1870 Views
Last post by wizechatmgr
