Hello everyone,
I have been having a problem with my 96 850R, it doesn't start, changed the PNP switch but didn't solve the problem. When I turn the key the dash lights come on but no crank, I think the alarm system blocks the car start, i tried locking and unlocking the doors with the key and didn't work, not sure what else to check. Any help would be appreciated.
96 850 - Alarm prevents car start
neworleans
- Year and Model: 2007 S60R
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 20 times
Is the red light on the dash flashing furiously when you turn the key?
'98 S70 T5
2016 Chevy Cruze Premier
neworleans
Unfortunately that light is broken
LakeFlambeau
- Year and Model: 98 xc 06 xc 07 xc
I had something like this years ago on a 97 850. I ended up jumpering out something to "remove
the system"
The following link gets you some information on it.
I do not remember the exact thing I shorted out, but I believe it was in this alarm
control module shown on page 4 and 5 of the link.
Maybe someone else knows the exact thing to jumper across.
This should get you close. Sorry, do not remember the exact details.
http://www.volvoclub.org.uk/tech/servic ... System.pdf
the system"
1998 XC, Now a 2nd 1998 XC 1998 S70
Previous
1997 850, 1992 740 Turbo Wagon. 1987 740 Turbo Wagon, 3 - 240's Various Years
Previous
- Year and Model: Many Volvos
- Been thanked: 76 times
The Anti-Theft / Alarm relay is a double relay located inside the car, mounted high on the firewall directly below the fuse box. The relay is number 210/211 and you need to remove the lower dash panel to get to it. The start inhibitor can be bypassed by removing the relay and installing a jumper wire between the socket positions associated with pins 50E and 50F on the 210 side of the relay.
Normally the hazard lights will be blinking when the alarm is tripped and the starter is inhibited. You might want to try using the service starter connection to try to start the car just to make sure the alarm is the problem. The service starter connection is typically a Red/Green wire with a terminal on the end of it that sticks out of the wiring harness near the left front strut. Hooking up + battery voltage to that terminal bypasses both the key and the alarm relay thus allowing the car to crank over if the PNP switch and the starter itself are both OK.
neworleans
Thank you very much for inputs, came out to be the ignition switch part number 9447803.
If you guys ever have any problems like this, start with the ignition switch
vikingleader
- Year and Model: 97 850 glt
Does the pulling of relay 210/211 and using a jumper doing the same as replacing the relay with Volvo part # 3545333?Ozark Lee wrote:The Anti-Theft / Alarm relay is a double relay located inside the car, mounted high on the firewall directly below the fuse box. The relay is number 210/211 and you need to remove the lower dash panel to get to it. The start inhibitor can be bypassed by removing the relay and installing a jumper wire between the socket positions associated with pins 50E and 50F on the 210 side of the relay.
Exactly the same thing. The Volvo bypass relay is easier to plug in but all it has inside of it is a wire.vikingleader wrote:Does the pulling of relay 210/211 and using a jumper doing the same as replacing the relay with Volvo part # 3545333?
- 697 Views
Last post by ThommyKent
- 3954 Views
Last post by ZootAllures
- 1888 Views
Last post by jonesg
- 2192 Views
Last post by Sailsman
- 1845 Views
Last post by rudsaki
