2003 Volvo XC70 Crank Pulley Nut
hellsbellsidaho
- Year and Model: 2003 XC70
I am trying to replace the timing belt on my Volvo but I haven't been able to remove the nut on the crank pulley even with an impact gun. Anybody have any suggestions?
chrism
- Year and Model: S80 / 2005
- Has thanked: 7 times
- Been thanked: 89 times
I've replaced the belt two different ways. Once removing the crank pulley, and once just removing the plastic cover that runs around the lower half of the space between the pulley and the engine. I prefer the second method. As I recall it's held in place with a 10mm hex bolt at each end of it.
IdahoBob
- Year and Model: XC70 02, 04 & 08
- Has thanked: 1 time
- Been thanked: 4 times
HBIdaho!
I fought an over-tightened nut for almost a month of evenings...
I tried:
1) 5' cheater bar on a 1/2"drive - this would not budge for me. Broke 2 extensions.
2) laying the breaker bar against the front frame cross member inside the engine compartment and hitting the starter. Nope.
3) In the end, I got out the sawzall, and very slowly cut a groove, diagonally across one of the flats of the nut. As soon as I say thread on the crankshaft peakign out of the groove I was cutting I sprayed WD-40 into the groove I'd cut, and then hit it with the electric impact wrench. It spun right off.
Order an extra nut (IPD) before you start, obviously.
Happy Motoring!
I tried:
Happy Motoring!
Idaho Bob
67, 71, 85, 98 wagons (sold)
78 coupe (gave to mechanic, thanks!)
02, 04 (X2) & 08 XC70's
before that: 67 Sunbeam, several pre-68 VW's, '41 Buick, '42 Ford Jeep, and some boring stuff
- 21 Replies
- 10535 Views
Last post by GBS
- 1084 Views
Last post by zombielinux
- 1509 Views
Last post by XC70Rider
- 962 Views
Last post by GBS
- 2870 Views
Last post by lummert
