2002 v70 Rear wiper stuck at 3:00
2001 - 2007 V70
2001 - 2009 S60
2003 - 2007 S60 R
2004 - 2007 V70 R
Grooveman221
Year and Model: 2006 v70
Post by Grooveman221 »
Hi all.
My rear wiper arm is stuck at 3:00. If I engage it, it goes down to my rear bumper. I took the cover and nut off. But can't figure out how to reposition the arm.
I've tried elbow grease once the cover and nut are off, but it doesn't budge.
I found a PDF on this site that says "remove arm" but it doesn't help
https://www.matthewsvolvosite.com/forums ... =1&t=20758
Grooveman221
I'm still stuck. Anyone had this happen before? I can't even remove the arm so I'm wondering if it's been tightened too hard.
Thanks in advance.
DGM
Year and Model: V70 2.4i 2005
Been thanked: 3 times
Post by DGM »
Remove the center nut and apply light penetrating oil (as WD-40 or similar product) at the junction of the arm & threads. Wait a few minutes. You have to move it side to side to break off the rust bond. Look at the following video to see how it is done.
See the following link on how to disassemble the mechanism. The white gear is often worn out. To my knowledge it is not sold separately. Also the shaft can rust inside its neck.
http://www.volvoforums.org.uk/showthread.php?t=71453
http://www.erievolvo.com/
http://www.southernvovo.com/
Hopes this help.
V70 2005 2.4i 195,000km, sold
S70 1998 T5 355,000km, sold
960 1994 80,000km, sold
760 1990 Turbo 265,000km, sold
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
Better use Liquid wrench Lubricating spray.
Grooveman221
Thank you forum!
Wd40 didn't work but the liquid wrench did.
