2003 S40 T3 VS T4
martin9586
- Year and Model: 2003 s40
everytime I shop for parts online I'm always asked if my car is a T3 or T4. How do I find this info.?
difflock54
- Year and Model: V40 Nordic 2002
- Has thanked: 7 times
- Been thanked: 2 times
Engine type will be a B4204T3 or a B4204T4 if its a 1948cc 4 cylinder.
Shows on the ID plate fixed on the firewall with the VIN number
martin9586
OK so I found the engine type. It wasn't on the I'd plate on the firewall, it was on a sticker on the hood. The engine type is listed as B4204T, but no 3 or 4. So what does that mean?
difflock54
Okay.
The alternative location should be a white sticker affixed to the side of the cambelt cover.
(In your case being the passenger side,front end of the engine.)
Immediately adjacent to the black power steering reservoir.
Mine shows B4204 T3. above that is the engine block serial number.
your engine ist B4204T have vvt? i also same with your engine b4204t got vvt. my timing belt cover missing when dilevery time. so do no its T3,T4 or T5. my frend have the same model b4204t and he mention that T5 refer to the cover timing belt.so now from engine number can know the category of the turbo?
- kcodyjr
- Has thanked: 17 times
- Been thanked: 23 times
The dealership should be able to look it up by the VIN.
5 others that came and went
difflock54
Found this from a post in another forum.
It may help you?
To carry on from Gmain's post... as a rule of thumb the early phase 1 T4 had the 1855cc unit with the phase 2 having the 1948cc unit, both T4 engines producing 200bhp/147Kw.
Phase I
1998 - B4194T = 1855cc (high pressure turbo)
1999 to 2000 - B4194T2 = 1855cc (hpt)
1998 to 2000 - B4204T 1948cc (low pressure turbo)
Phase II
2001 to 2003 - B4204T5 = 1948cc (hpt)
2001 to 2003 - B4204T3 = 1948cc (lpt)
It may help you?
Phase I
Phase II
hi guys,difflock54 wrote:Found this from a post in another forum.
It may help you?
Phase I
Phase II
question on phase I model 1998-2000 B4204T 1948cc have use VVT?
- 1206 Views
Last post by alschnertz
- 717 Views
Last post by oragex
- 867 Views
Last post by steve090
- 1361 Views
- 956 Views
Last post by Vovo_merz
