The car starts quickly then quits after 1 or 2 seconds. Cranking the starter again right away repeats the symptoms. Stepping on the accelerator while the starter cranks gives higher revs but only for a second or two, then quits.
It seems like there is enough fuel for a start, then the fuel runs out, then replenishes for the next start. Plenty of gas in the tank. I replaced the fuel filter with no effect. 25 AMP fuse is continuous and clean. Flame trap is clean. Fuel pressure test next? Any ideas? Thanks for the help.
1986 240DL starts but won't idle longer than about a second
- 2380 Views
Last post by RickHaleParker
- 15 Replies
- 3003 Views
- 1281 Views
Last post by mountaincarjunkie
- 459 Views
Last post by June
- 1758 Views
Last post by doublebug
