Did you know? 🤔
A Box of Throttle Bodies. 3 Inch Turbo Conversion.
How to go faster, stop quicker, and turn harder. Chips, exhaust, larger turbos, bigger/slotted/drilled rotors, high performance brake pads, manual boost controllers, performance shocks/struts/springs, airbox mods and more! Also discussion on HID and Xenon lights, aftermarket foglights and other exterior lighting.
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 603 times
Been thanked: 246 times
United States of America
matthew1
Re: A Box of Throttle Bodies. 3 Inch Turbo Conversion.
Post by matthew1 » Tue Mar 25, 2014 2:27 pm
Ben, I put in a 628 a couple years ago, but I didn't notice any difference. It may be that a bottleneck, or the MBC, is masking any changes the 628 made.
Also -> Amazon link
. Click that when you go to buy something on Amazon and MVS gets a kickback.
1997 850 T5, MSD ignition coil, Hallman manual boost controller, injectors, R bumper, OMP strut brace [gone]
Ben850
Has thanked: 0
Been thanked: 4 times
Ben850
Post by Ben850 » Wed Mar 26, 2014 7:17 am
matthew1 wrote:Ben, I put in a 628 a couple years ago, but I didn't notice any difference. It may be that a bottleneck, or the MBC, is masking any changes the 628 made.
I would imagine the MBC is overriding any difference in the boost mapping.
I haven't installed an alternate boost control so I should see some difference with an R ECU hopefully.
1996 850 Turbo Wagon White.
1994 850 N/A Wagon Black.
1997 850 Sedan Black.
1996 850R Wagon White.
Ben850
Has thanked: 0
Ben850
Post by Ben850 » Sat Mar 29, 2014 5:06 pm
I dropped in the 628 R ECU today.
After driving it shortly last week with the 072, I did notice a difference.
Now, with the 628 unit at around 2,500 rpm while the boost is coming on, it fells like a second wave of boost kicks in for around three seconds or so. I look down and I am at 60 mph.
The fact that I changed to a 3" N/A intake manifold and 3" air intake to turbo seem to have added some quicker throttle response, spool and likely a few horsepower.( IPD says about 10 just for the air tube to turbo.)
I feel a definite difference as a result of these simple bolt ons and drop in. I believe the R ECU added something overall as well.
Now if it will only get warm out. I still have to sort out the power issue to my ECC.
matthew1
Site Admin
matthew1
Post by matthew1 » Sat Mar 29, 2014 5:15 pm
Very good.
Also -> Amazon link
epukerob
Year and Model: C70 1999, S80 2003
Has thanked: 0
Been thanked: 0
epukerob
Post by epukerob » Sun Apr 27, 2014 8:16 am
Matthew/Ben - It would be great to get a full run-down/list of these mods and parts to look for. Or is this summarized elsewhere on the site?
Ben850
Has thanked: 0
Ben850
Post by Ben850 » Mon Apr 28, 2014 9:37 am
epukerob wrote:Matthew/Ben - It would be great to get a full run-down/list of these mods and parts to look for. Or is this summarized elsewhere on the site?
I would be happy to put a list together and itemize the parts for you.
I had just returned from work out of town , and recovering. I'll start on that later today. I just finished shipping a set of white injectors out that I had leftover from my fun.
epukerob
Has thanked: 0
Been thanked: 0
epukerob
Post by epukerob » Mon Apr 28, 2014 12:44 pm
Thanks Ben! I also notice my 98 C70 (2.3L HPT) already has "white" injectors - is there a spec or p/n for these? I figger to support ~300HP they would need to be 42~45 lb/hr rated at ~40psig. Any details available on those "white" goodies anywhere??
Ben850
Has thanked: 0
Ben850
Post by Ben850 » Tue Apr 29, 2014 6:08 pm
Here are a few things to look at while I compile a list for you.
The white injectors are PN 0280155766. You can see their statistics on the chart located here.
http://www.fuelinjector.citymaker.com/F ... Rates.html
And here.
http://www.justfuelinjectors.com/servle ... wchart/Pag
Whites are 350cc.
Blues are supposed to be 395cc.
Greens 0 280 155 968 are 440cc.
I will get back soon.
Ben850
Has thanked: 0
Ben850
Post by Ben850 » Mon May 05, 2014 3:40 am
I have a comprehensive list. Part numbers can be researched.
Most everything was bolt on. The only modification needed was a tap into the manifold to take vacuum to the turbo.
I did also tighten the waste gate actuating rod two full turns while I was in the area.
I still have an exhaust manifold from an '04 S60R that I may install over the summer. If so I will likely attack those heater core hoses, and core itself. Maybe even a 19T. We will see, it is getting to be scary acceleration as it is.
The turbo has almost no play in the shaft, luckily.
I did not take photos while tapping for the fitting. I was in total work mode.
List of parts I had used:
White injectors.
N/A manifold from '98 S70.
3" N/A throttle body from '94 Sedan. (does not need to be year specific.)
960 N/A throttle plate.
Bosch "628" R ECU from a '96 855 R.
Aftermarket pieces would include:
Snabb 3" silicone throttle body intake tube adapter for turbo.
As a personal addition Snabb 3" aluminum intake tube from the air box to the turbo. W/3" silicone adapter hoses.
FCP sport silicone intercooler hoses.
Also added a Snabb upper IAC hose for good measure. (looks good too)
After. The other blue hose across the manifold is 5/8" from oil separator to PTC.
osman
Year and Model: 2002 c70 hardtop
Has thanked: 0
Been thanked: 0
Algeria
osman
Post by osman » Thu May 22, 2014 1:44 pm
I already have a NA intake manifold lying around and a 960 throttle/body plate is easily attainable. Seems like a nice addition to my T5 motor/turbo/ecu swap with white injectors. Instead of tapping a third intake manifold hole for the turbo vacuum, why not just use one of the throttle body "tree" options?
So Should I use the throttle body itself from the 960 or just the plate in a 850 TB on a 850NA intake Manifold, also have you done the NA cams mod?
Brick Life
2003 Saab 9-5 ARC V6 3.0 Turbo 120K SwagWagon
97 850R wagon mileage unknown
2000 C70 Turbo Convertible 110K
99 XC70 AWD LPT 115
98 BMW 328IS 130K M3 Wheels
94 Mercedes 420E 160K
Kiwi bluetooth/Torq Pro app VOL-FCR/VAG-COM USB cable
