I'm getting a code P1618.
The transmission will not reverse when throttle is applied. it will back up when it is idled.
It seems fine in all forward gears.
Background: I had it in reverse, my foot on the brake and one foot on the gas. i reved it a little to see if it would build boost. something popped. I'm suspecting internal damage of some sort. i only reved it to 1500 RPM. i can't believe that would have killed reverse.
Is there some sort of bevel gear that could have snapped?
2000 V70 XC T AWD Transmission Reverse not working
sawtooth4x4
- Year and Model: 2000 V70 AWD T5
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 20 times
I had a solenoid blow clean out, but I figure that's pretty rare. Check the fluid level and condition via the dipstick. If it's low or very dark, a drain-and-fill of fluid may do the trick for you.
Is your AWD driveshaft intact? A front axle could have popped out of the transmission entirely if the car is only being run as FWD.
'98 S70 T5
2016 Chevy Cruze Premier
