2003 Volvo XC70 Low Compression after timing belt
hellsbellsidaho
- Year and Model: 2003 XC70
I have a 2003 Volvo XC70 that I just replaced the rod bearings and the timing belt. Before this it had compression of 145-150 but after it is as low as 50. The timing belt is aligned between the crank and the cams. Anybody have any ideas?
JDS60R
- Been thanked: 3 times
I can't see the mark in the middle picture.
In order to help we need some info
What did you do to prep the VVT for alignments. Pass timing mark 90 degrees and then go back to relieve vvt ?
Did you manually turn the crank 2 rotations after installation , then move and extra 90 degrees and turn back to marks to check?
Retired
- 23 Replies
- 6420 Views
Last post by precopster
- 24 Replies
- 1465 Views
- 1775 Views
Last post by Livens
- 1207 Views
- 23 Replies
- 18042 Views
Last post by jonesg
