2002 2.4t Oil Leak
My 2002 2.4t has a oil leak from somewhere above on the oil filter side of engine. Any Ideas where it myight be coming from? It dose not appear to be a valve cover gasket and it there is a decent amount of oil on the ground. The car has never had any leaks before and its right at a 150 thousand miles.
difflock54
- Year and Model: V40 Nordic 2002
- Has thanked: 7 times
- Been thanked: 2 times
That location could be your front camshaft seals or maybe your front crankshaft seal.
Remove your timing belt cover and see if there is evidence of oil flying about.
It would also run down towards your oil pan and oil filter area from there.
May be caused by the PCV system if it is in need of servicing as the crankcase pressure builds up if it is clogged and blows the engine seals.
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
difflock54 wrote:That location could be your front camshaft seals or maybe your front crankshaft seal.
indeed check pcv system, clogged it builds up pressure inside the crankcase and sludge in the oil pan that eats up the rod bearings
- 2512 Views
Last post by chrism
- 1426 Views
Last post by t3yf5g
- 1417 Views
Last post by mrscullini
- 3145 Views
Last post by Stephen0523
- 971 Views
Last post by vtl
